Old 03-27-2016, 03:01 PM   #31
Austintatious's Avatar
Originally Posted by Ky-N View Post
Ours is a 2016 also. Must be some small difference in the way the supports were installed.
I'll bet you could get a shackle lift kit (around $25) and replace the rear shackles for enough clearance to fit 15" wheels/tires for better handling and improved clearance.
Austintatious is offline   Reply With Quote
Old 03-27-2016, 07:32 PM   #32
Already flipped the axle, it was easy. Completed it in less than 4 hours doing all the work without any help. Plenty of clearance now for the 15" tires.
I had thought about longer shackles but the geometry was all wrong, it would have ended up breaking a spring or some other damage. Flipping the axle is the only way to do it an maintain proper function of the suspension.
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
