Old 08-15-2012, 02:38 PM   #11
Broadway Joe's Avatar
Most of the handles for the emergency window I have seen are notched on the bottom, meaning you lift the handle just a tad to allow them to close. Try placing a small tapered shim into the top opening where the handle travels to see if that will keep it open?
Broadway Joe is offline   Reply With Quote
Old 08-15-2012, 03:02 PM   #12
Herk7769's Avatar
What ever you do remember it is an emergency exit. The bar is designed to go THROUGH the hole to let the window swing free so you can drop to the ground.
HAM CALLSIGN - KC3FFW
Old 08-15-2012, 03:20 PM   #13
Originally Posted by BlakeB View Post
ahhhh....being impaled once in a while never hurt anyone
Oh, I PALE at the thought...........
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 08-15-2012, 03:24 PM   #14
YES, INDEED!
I was thinking of a blockage (nail dropped in hole) OUTSIDE
the place where the bar meets the frame. That would prevent
the window closing, but present no obstacle to pushing it
open.........always be safe......
cheers,
johnd
Old 08-15-2012, 03:36 PM   #15
Terier's Avatar
I'm a little unsure of what your window looks like. I do keep my emergency window open but there's a notch in the handle that keeps it in place. On mine it takes a bit of pressure to release it to close. We might not have the same window.
Old 08-15-2012, 03:36 PM   #16
How about turning her around so her feet are at the window instead of her head.
comfun1 is offline   Reply With Quote
Old 08-15-2012, 03:56 PM   #17
TURBS's Avatar
Window is at her side if I'm not mistaken
Old 08-15-2012, 04:22 PM   #18
I think in an emergency, any window whether closed or not would not be much of an obstacle. In our trailer, the emergency window is in the bedroom and it is a 7-1/2 ft drop to the ground. We'll go out the door.
Old 08-15-2012, 04:26 PM   #19
I think that that is what the OP was describing. Mine is exactly
like that too. It may have required much pressure to release
when new, but now in my older TT, the weight of a gnat's
backside is about enough to release it. Bedding rubbing
against will surely release it every time.......
cheers,
johnd
Old 08-15-2012, 04:52 PM   #20
Herk7769's Avatar
Originally Posted by dnaraG_1M View Post
YES, INDEED!
cheers,
johnd
This is a good solution!
bunk, bunkhouse, catalina, emergency window
