Old 10-05-2016, 01:02 PM   #11
Canadian Member
itat's Avatar
You have to level before putting the slide out. Once the slide is out, you shouldn't be moving your camper.
I have a 16' long super slide in my TT but it only has the U dinette and sofa in it - no heavy appliances. It doesn't change the slope when I put it out. If yours does affect the slope, you'll have to figure out how much it throws off your level's bubble and adjust for that when levelling before putting out the slides. After a few adjustments you'll have it figured out and be good to go from then on.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 10-05-2016, 01:21 PM   #12
RSchleder's Avatar
We set up the camper to be higher on the slide side before putting the 2 slides out. On most camp sites assuming they're fairly level, we put 1 orange plastic "spacer"block under the tires ON THE SLIDE SIDE. This will make the bubble almost touch the line on the slide side. After a few hours of sitting with the slides out, the weight of the slides tends to cause that side to drop and we sit nice and level for days/weeks on end.
Days camping (2016)----181 days
Days camping (2017) --- 14 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 10-05-2016, 01:25 PM   #13
We have to adjust the level of our TT buy 3/4 inch. When we were leveling before putting the slides out, I always felt like my head was down hill of my feet.
awhite64 is offline   Reply With Quote
Old 10-05-2016, 01:30 PM   #14
Boso's Avatar
Leveling
If your slide unlevels the camper then you need to see how much then level with that side higher that amount. I had that problem with a tag along one time the rv's will almost always be the same amount unlevel if you don't take that into account. But after you figure that out level then slides then stabalizer jacks as they are not for leveling
Boso is offline   Reply With Quote
Old 10-05-2016, 02:16 PM   #15
Level before putting slides out.
RLHAMILTON is offline   Reply With Quote
Old 10-05-2016, 02:22 PM   #16
Cfritts's Avatar
Agree level up
We have the Forester 2401WS, full wall slide and we have to adjust for that going out as the entire rig leans in that direction. Check level, slide out, check, slide in, level blocks, slide out, check.
It is very noticeable for me, my husband must be part mountain goat as he has no issues but I hate feeling like my head is sliding into the wall, or I am sliding out of the bed or the bathroom door not staying shut or open.
Cfritts is offline   Reply With Quote
Old 10-05-2016, 02:29 PM   #17
Dave Lyon's Avatar
Level - front to back and side to side, stabilizers in place.....then put out slide.
Dave, Southern,ON
2009 GMC K1500 4x4 Crew Cab
2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 10-05-2016, 02:34 PM   #18
We have 2 slides on one side, one is very large, we have to start with the slide side high. Like most are saying stabilizers are not for leveling.Your axle springs will sag towards the slides.
03Ram2500
16Hemisphere302FK
Bear fans is offline   Reply With Quote
Old 10-05-2016, 03:16 PM   #19
genehorn's Avatar
I would level before the slides go out or at least get close. I have been told that the slide motors have a little easier time when things are close to level and might not like pushing a slide uphill.
Gene
2016 Wildcat 28SGX
2016 GMC HD Duramax
genehorn is offline   Reply With Quote
Old 10-05-2016, 03:28 PM   #20
I still always have leveled before putting them out. How much it changes after that depends on the type of leveling/support system you have. It doesn't matter a whole lot, since no matter what you do, every single inch of your RV is never completely level. It changes, depending on where it is measured. The trick is to pick someplace to measure, so you get it close.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
42 nights camping in 2015
61 nights in 2016 (still not enough!)
ben31 is offline   Reply With Quote
slide
