Old 02-07-2014, 04:44 AM   #1
Location of Black water valve chapparal lite
Can someone tell me where the three valves are located on the 2010 268 RLE Chaparral lite? Just purchased unit and can only find two valves
rjsamson is offline   Reply With Quote
Old 02-07-2014, 06:41 AM   #2
Ford Idaho's Avatar
Length (ft/m) 30.58 / 9.3 Width (in/mm) 96 / 2438.4 Height (in/mm) 143 / 3632.2 Interior Height (in/mm) 76 / 1930.4 Length (ft/ft) 30 Length (ft/in) 7 Dry Weight (lbs/kg) 6877 / 3119.4 Payload Capacity (lbs/kgs) 2349 / 1065.5 Hitch Weight (lbs/kgs) 1226 / 556.1 Capacities Standard Number Of Fresh Water Holding Tanks 1 Total Fresh Water Tank Capacity (gal/l) 47 / 177.9 Number Of Gray Water Holding Tanks 1 Total Gray Water Tank Capacity (gal/l) 84 / 227.1 Number Of Black Water Holding Tanks 1 Total Black Water Tank Capacity (gal/l) 42 / 113.6 Propane Tank (s) Standard Number Of Propane Tanks 2 Total Propane Tank Capacity (gal/lbs) 14.2 / 60
This says you have One fresh, One gray and one black tank.
http://www.rvguide.com/specs/sites/r...parralLite.jpg
Old 02-07-2014, 06:58 AM   #3
Dave_Monica's Avatar
Welcome to the forum!
To clarify, when you say you've found two valves, are you indicating two, separate valves into one sewer connection or two separate valves and separate sewer connections.
The normal set-up would be one grey tank valve and the black tank valve into one sewer connection and the second gray (or galley) tank valve into a second sewer connection. If the gray tank capacity is 84 gal, that would be 2 - 42 gal tanks.
Infrequently, the factory will plumb the two gray tanks together, but they would still have separate valves.
Dave
Old 02-07-2014, 11:14 AM   #4
RKR
RKR's Avatar
I have a '13 Chaparral Mid Profile. Like it was mentioned above I have 1 black tank valve and 2 grey. I have one black and gray valve in the utility area and one conveniently hidden gray tank valve behind the driver side rear wheel that's dumps the galley tank.The gray tank valve behind the wheel was not marked.
Hope that helps you
RKR is offline   Reply With Quote
Old 02-14-2014, 08:51 AM   #5
Thanks everyone. Sorry I did not reply earlier but I finally found all three valves:
-One for the human waste tank located in the water control compartment. This one was easy!
- one in the frame under the water compartment. Unexpected location!
- one in the frame behind the rear tires drivers's side.
There are three separate tanks: 2 grey water and one for the black water.
Old 02-14-2014, 09:03 AM   #6
Ford Idaho's Avatar
Not an issue, some of us have a lot going on with the weather and what not.
Glad you got it worked out and thanks for posting back with the locations in case someone else has the same problem.
Old 02-14-2014, 09:07 AM   #7
You have (3) valves,how many sewer hose (outlets) are under your unit? Youroo!!
black, black water, cat, location, water
« shades | Humidity »
