01-23-2018, 01:35 PM
Looking for 12 Volt Tire compressor/inflator
I have a 2013 Coachmen 281RLDS travel trailer with 15 inch wheels and require a tire pressure of 50 psi. I'm looking for suggestions on a decent 12 Volt unit that I can use to fill my tires in the RV Storage lot. I don't have a generator so I assume I would have to run the compressor/inflator off my truck battery.
01-23-2018, 01:42 PM
geezer with gadgets
This thread might be of some help...
http://www.forestriverforums.com/for...ors-91101.html
Good luck with your research!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
01-23-2018, 01:49 PM
I had an expensive ViAir just burn totally up.
FROG AR-0019-242
01-23-2018, 02:23 PM
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
01-23-2018, 02:25 PM
Insert witty title here
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
01-23-2018, 02:50 PM
Viair 450P has been great for 2 years but it was expensive. Probably average using it every couple of months over the last 20 months, so not excessive usage.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
01-23-2018, 02:53 PM
Always Learning
I love my Viair:
Product Review: Viair 450P 12v air compressor | Learn To RV
BandJ, what was the circumstance? Did you contact Viair about it? I haven't read much negative about them and am curious.
01-23-2018, 02:56 PM
Originally Posted by ependydad
No, I should I guess. Truth is, I can't find the original receipt so I doubt it'd do any good. I got sick, and stopped looking.
When I left to come here snowbirding, I used it to air up tires.........BTW all my tires, trailer and truck, were bad low. I would plug it up to battery, turn it on, and it'd pop the fuse. Looked in and it had 40a inline fuse. But holder says 30a. So I got both. And tried every other kind of battery to plug to. Multiple times. It would get hot, smoke come out, pop fuse, and that was the end. Every time.
FROG AR-0019-242
01-23-2018, 03:22 PM
Always Learning
Dang. Please contact them even w/o a receipt. I'd love to hear what they say (and will likely update my post to reflect it).
I've ran mine for a good long while- 4 tires had to come up 20 psi when I aired down my duals once and then the other 6 all needed air because it had gotten cool. Another time I filled a small pool that took a good long time. And even another time, I filled something like 8 river floats.
The only issue I had when I was doing all of the tires- is I blew out the side of the cheap hose they give you.
01-23-2018, 03:26 PM
OK, just for you. And if I forget to post it here, I'll tell you via PM.
Yeah, I wanted to replace that POS hose, too.
I just filled out the online email warranty form. I do NOT have the unit, and won't be home to get it until April 2nd. BUT......I doubt it's under warranty. I did a search of my Amazon orders (another benefit of using Amazon) and found the receipt. However, I bought it May 27, 2016.
So I dunno. I doubt they do anything. But I will let you know.
Meanwhile, I'm seriously considering (ONLY when I next need tires) upgrading to 17.5" G114's, which are 125 lbs of air. I dunno what portable unit to get. The one I had would do the job, IF you had a half hour to wait.
FROG AR-0019-242
01-23-2018, 04:01 PM
Always Learning
My Viair 450P does 125psi on my LR J tires (Continental HTL something or other). It is actually fairly quick as I picked up the camper after a service visit and found 1 tire at 80psi. Pumped it up and took it to a tire shop to have a nail pulled + patched.
But, I can understand if you're gunshy on the Viairs.
01-23-2018, 04:14 PM
As a rule of thumb, you do *not* want one that plugs into the 12V outlet in the vehicle. The motor is relatively weak as to not blow the fuse for the outlet.
I carry an (insert arbitrary brand name) MV50 in the truck and so far it has worked well.
01-23-2018, 05:37 PM
I did not plug into the 'cigarette lighter'. I used alligator clips for all batteries.
I just got an email back from them. They asked if I would be ok with sending it back to them, to see if they could repair it. I said that was awesome, BUT I left it at home and won't be home till April...............
FROG AR-0019-242
01-23-2018, 05:46 PM
Hey look in this forum's product reviews, I bought the Costco power station air compressor and jump starter, inverter and worked great when u had to put in 15 psi in four of the tires to get then to 65psi
01-23-2018, 06:22 PM
I personally hate the 12V compressors. I would rather have a 120V model with a 150 PSI capability and can fun from my 3500 Watt Generator.
Gets the job done faster and less chance of burning up some wires.
Absolutely avoid any compressor that plugs into the cigarette lighter. Almost every one I've seen ends up burning up the plug itself because they put out such a small volume and have to run 30 minutes to an hour to pump up a flat tire.
01-23-2018, 09:46 PM
Try this one. Slime 2X Heavy Duty Tire Inflator. Have one and love it.
01-23-2018, 09:54 PM
Yep, I've been using a comparable Slime compressor for several years. I put 75 lbs. in my trailer tires.
Nope......... I doubt if it will put 110 lbs. in a tire.
01-23-2018, 10:23 PM
I have a DeWalt 2 gallon 110v air compressor with 150lb regulator in my basement. It was very handy in northwestern South Dakota last August when I kept losing air in my left front tire late on a Saturday afternoon. It was also convenient that I could start my Cummins Onan 5500 to power it.
I too have my frustrations with several brands of 12v compressors running forever and blowing multiple fuses.
If you carry a generator, go for a good 110v unit.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
01-24-2018, 01:45 PM
I have MasterFlow MF-1050 Air Compressor good to 150 psi about $60 in 2016 great buy
Wayne Knott
Georgetown GT3
