Old 09-06-2014, 12:18 AM   #1
Roganravenwood's Avatar
Looking for winterizing info 310bhds freedom express maple leaf edition
I forgot to ask the dealer where the connection is for winterizing the new trailer. 2014 310 BHDS freedom express maple leaf edition. I can't seem to find this. Also, never dealt with "low point drains". I presume that's to drain any low points in the water lines. Just not sure where I add the antifreeze. Oh, and is it necessary to winterized the black tank spray connection? Thank you for the input.
Roganravenwood is offline   Reply With Quote
Old 09-12-2014, 07:13 AM   #2
snapper's Avatar
I have the same unit and the pump is located under the fridge. In order to get to water pump you have to remove the outside slide out drawer on the right side of the trailer, Right by the wheels. Once removed you can access the pump. You will need a pump winter kit so you can suck antifreeze in the trailer water lines to make it work. I got mine from the dealership and installed it myself. If you are not sure how to install it ask the dealer for help. Its not a big job.
snapper is offline   Reply With Quote
Old 10-11-2014, 10:20 PM   #3
I got the winterizing line installed. On the intake side of the pump was what looks like a cheap water filter with a small metal screen filter. Is it necessary to put this back in? Would have to relocate the pump to fit this piece back in.
Old 10-12-2014, 05:22 PM   #4
My site glass was fitting cracked when tightening it back up so I just removed mine and put the 3-way valve in its place.
TEMPEST is offline   Reply With Quote
Old 10-14-2014, 04:15 AM   #5
snapper's Avatar
That's what I did with mine as well. I only use full hookup so I don't use the pump much. Just make sure nothing leaks and make sure you drain the water from the hot water tank and pull the low point water line plugs under the outside kitchen. Once all the water is out start filling with the pink stuff.
freedom express, winter, winterize
