You need to either buy a propane hose with male fitting on one end and quick disconnect on the other the proper length to reach your BBQ or install a propane quick disconnect at the manifold and a hose of the proper length with male quick disconnect fitting on the BBQ I'm saying propane quick disconnect because they look just like air fittings but the air fittings are not the same size and will not work on propane.
Retired Navy
2016 Flagstaff 26 FKWS
