Manual slide in? 2016 Coachmen Freedom Express 246RKS
I've done some searches here and elsewhere but haven't found my answer so am hoping someone can assist. (I've also left a message with FR/Coachmen, waiting for call back.)
Twice in the past month my slide out has failed to slide in when I pressed/held the switch, and I had to cancel/delay trip. I won't go into what I did to get the slide electrical components working again ...my question is, how to retract manually? The Lippert Component Systems owners manual is very general and gives instructions for multiple components and models, none of which seem to be my particular slide out. The local dealer (I didn't buy mine there) didn't have specific instructions, just told me to look where the slide motor is and instructions for manual operation would be printed there; but they are not. There is nothing on the outside that would facilitate manual cranking. I tried disconnecting the electrical components from the slide control box and then tried to push it in manually from outside, but wouldn't slide. I'm thinking there must be some type attachment that either attaches to the tiny metal pin sticking out of the motor, or a special socket/crank that attaches to this other metal rod, and would thus allow manual cranking. (See attached photos.) I'm basically living in fear of the day that I get somewhere and this thing won't work on electric and I'm stuck. I'm a full timer, so even though my small physical size does allow me to squeeze through without ever using the slide, it's very cramped and my normal sized visitors can't squeeze into bathroom with the slide in.
Thanks!
Lisa
Full Time Rv-er
