Old 07-07-2013, 01:18 PM   #1
Mattress
Hi, has anyone changed out their Short Queen mattress in the master bedroom?
I purchased a new 320 BHDS and noticed the short queen mattress is shorter than our old camper. Measuring 60" X 73" it is shorter and much harder.
Here is the camper mattress sizes, I find it odd it measures shorter than what it is suppose to be?
  • Three Quarter Size : 48" x 75"
  • RV Full: 53" x 75"
  • Short Queen : 60" x 75" (most common short queen size)
  • Short Queen: 60" x 74"
  • RV Queen : 60" x 80"
  • Olympic Queen : 66" x 80"
  • RV King: 72" x 75"
  • RV King: 72" x 80"
  • Cal King: 72" x 84"
  • Eastern King: 76" x 80
  • RV Bunk: 28" x 75"
  • RV Bunk: 30" x 75"
  • RV Bunk: 30" x 80"
  • RV Bunk: 34" x 75"
  • RV Bunk: 35" x 79"
  • RV Twin : 38" x 75"
  • RV Twin : 38" x 80
  • RV Bunk: 42" x 80"
Super 8 is offline   Reply With Quote
Old 07-07-2013, 01:25 PM   #2
Funny, you don't have the one in my Roo19 - 60 x 72. (Which I thought was known as an RV Queen, not 60x80.)
Old 07-08-2013, 11:19 AM   #3
daydreaming about camping
jeeplj8's Avatar
We put a memory foam topper on ours. It is a full queen size so it hangs over the end. This works well because it is plenty flexible to push by when walking around the bed, but still makes the bed a little longer.
I dont think it would be any problem replacing the mattress with a 74 or a 75, it is just going to be slightly closer to the bathroom wall.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-08-2013, 12:07 PM   #4
Is your fridge on your 320 really noisy inside and out when it is running?
Also, I noticed you wrote you had a bungee cord on your propane tank cover, mine does not have this. I had to widen the tanks for the cover to fit snug.
Thanks for info; Les..
Old 07-08-2013, 12:23 PM   #5
jeeplj8's Avatar
The outside fridge sounds like every other 110v small fridge, and you can hear it kick on when you are in the bunkroom.
The inside fridge makes different noises since it does not have a compressor. I frequently can hear the fans from inside, and while they somewhat load, I think the sound is normal. I am always surprised when it is on propane and I stand outside that I can hear the propane igniter and then the flame burning.
Our cover came with a small black bungee underneath.
Old 07-08-2013, 04:16 PM   #6
I meant the inside fridge making noise that you can hear outside. It is like a squealing fan with a bad bearing.
Old 07-08-2013, 04:17 PM   #7
jeeplj8's Avatar
no - do not have that at all.
Old 07-13-2013, 07:59 AM   #8
We ended up pulling the mattress down a bit, rolled up a couple of rugs for fillers before adding a pillow top type topper.
