If you camp in a cold environment, the moisture from your body will easily penetrate the mattress and condense when it hits the cooler bed frame/deck. Not sure of the configuration of your unit, but an unheated storage area under the bed will cause the bed deck to be cold. The amount of condensation will increase if you have a high metabolism at night. To prevent this, you need to insulate the bottom of the warm mattress from the cold bed deck. A sheet of 1/2" construction foam works great. You are going to need to take the mattress out and treat it and start over.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
