Old 10-14-2014, 01:05 PM   #1
Mice entering camper
I have a 312 bhds and the power cord comes out of the back left side of the camper. We leave it at a seasonal site for the summer. There have been a couple mice that have come in by climbing the power cable. I have set up a trap by the box were the power cable comes in and caught one on a sticky trap (he then got me back by chewing through some small wires). How can I stop them from climbing up the cable? The hole they are getting into is small but so are they. Here are some pictures of what it looks like. Click image for larger version
Name:	ImageUploadedByForest River Forums1413309759.316519.jpg
ID:	64733Click image for larger version
Name:	ImageUploadedByForest River Forums1413309785.524214.jpg
ID:	64734Click image for larger version
Name:	ImageUploadedByForest River Forums1413309805.656662.jpg
Thanks for your help
Todd
2014 Coachmen 312 BHDS
tmiller is offline   Reply With Quote
Old 10-14-2014, 01:25 PM   #2
TURBS's Avatar
Install a cat inside!
Seriously stuff that hole with steel wool.
My mil swears that stuff stops mice.
I'd belive it to since I've yet to see a mouse or it's tale tell signs!
Turbs
Old 10-14-2014, 01:48 PM   #3
You could retrofit a plug in connection. Its kind of expensive but no more mouse hole.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is online now   Reply With Quote
Old 10-14-2014, 02:22 PM   #4
Paradise has arrived!
Paradise115's Avatar
The steel wool should help. If you are not constantly plugging in unplugging you might try screwing the cover shut. It should take the mouse family at least a few years to find and learn how to use a screwdriver! Or they'll have to call a handymouse and we all know how long it'll take her to get there. (I'm told all handymice are women.)
Paradise115 is offline   Reply With Quote
Old 10-14-2014, 03:12 PM   #5
realebill's Avatar
cut a circle of 1/4" mesh hardware cloth the same diameter as the indent in that entry.cut a slit in it and then cut out a circle the same diameter as the 30 amp wire.slide it over the wire and push it into place and close the cap..... e z pee z !
or,you could even cut the same configuration out of a plastic lid if its big enough to cover the inside of the entry
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 10-14-2014, 04:20 PM   #6
ColoradoRick's Avatar
When we had our house built in 2003, we had a terrible time with field mice getting into the garage.
I tried those glue traps (a horrible invention...especially when the mice don't die and are out there screaming) and the old-fashioned spring-loaded kind...but a little gruesome, too...
But, man, these electric mice zappers are awesome and work! The couple of mice I had to get rid of were drawn into them within hours and the 4-AA batteries killed them instantly. (Peanut butter seems to be irresistible to them.)
You may want to leave out outside the camper for a while...I'm betting you'll get quite a few!
Rat Zapper Classic Electronic Rat Trap-RZC001 at The Home Depot
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-14-2014, 04:25 PM   #7
fonzie's Avatar
Copper wool is best for preventing mouse infiltration and does not rust......
Can steel wool stop mice? - HowStuffWorks
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-14-2014, 04:45 PM   #8
themounties's Avatar
Along with the wool you can goop up the cable with some Vaseline, just remember it's there don't ask me how I know. lol I read on here somewhere it was good for ants, maybe mice too.
themounties is offline   Reply With Quote
Old 10-14-2014, 04:49 PM   #9
You can capture one and torture it nearly to death.. Then release so he can tell they others of your sadistic ways... But I can tell you that doesn't always work..lol..
Or you can use some hardware cloth with a slit for the cord... I have used this method in the past and am using it as we speak as I keep my MH plugged in during storage in my yard and nothing has gotten in yet...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-14-2014, 04:59 PM   #10
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Like fonzie said, copper wool works and does not rust. Don't use STEEL wool unless you want rust marks running down the side of your rig. You can also use brass wool that won't rust either. You can find it at some hardware stores, but the best place is marine supply shops. Boaters would not want steel wool any where around their boats and RVer's shouldn't either.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-14-2014, 05:20 PM   #11
I agree with the copper/brass wool to stuff. I'd also add some oasis (the green foam that florists use) soaked with peppermint essential oil. They hate the smell and avoid it.
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
Old 10-14-2014, 09:01 PM   #12
A round plastic insert like suggested in a previous post would be the simplest and easiest if made out of a coffee can lid, etc. inserted inside the compartment. Even the top portion of a plastic soda or water bottle would work.
Old 10-29-2014, 08:12 PM   #13
Flybob's Avatar
Get a bottle of essential oil of peppermint. Put a few drops on a cotton ball or two and place them in an old juice glass or ash tray and put one in front and one in back. I have had mice in my garage for years, but none in my RV that is parked next to the garage. You need essential oil, not peppermint used for cooking, Also do not get it on floor or cabinets as it will damage them.
camper
