Old 06-17-2015, 07:44 AM   #11
MilCop4523's Avatar
Originally Posted by John Forish View Post
We had the same problem with out travel trailer. I sprayed the bottom of the trailer with a product called Mouse-Free. Kind of a weird way to put it, but I don't know if it worked or not, we haven't had a visitor since.
Mouse free is anther product that works however it tends to wash off hauling in teh rain and it is expensive.
ok if you are a "Start and Park" kind of camper.
2009 Heartland Sundance 31.5 XLT bunkhouse
2013 Ford F150 XTR ECOBOOST
"Of the troops - For the troops "
MilCop4523 is offline   Reply With Quote
Old 06-17-2015, 08:22 AM   #12
We had done all of the suggestions - dryer sheets, steel wool, traps, etc. The only way we were able to stop them was to us the spray foam around the bathroom sink drain pipes. Haven't had a problem since.
BillConnie is offline   Reply With Quote
Old 06-17-2015, 10:50 AM   #13
[QUOTE=MilCop4523;896133]the light trick will work just fine - but if you can't get to some spots to seal do yourself a huge favor and search out a product called FRESHCAB
Have heard real good reviews of Freshcab. But for some reason the Canadian customs stopped the import ( so I was told by dealer who sold it before) of Freshcab, something in it they didn't like!!!. I use peppermint oil now and it works real good, smells nice also!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-17-2015, 02:20 PM   #14
TnT's Avatar
I just pulled off every panel I could and filled every hole that went thru the floor with Great stuff in all the campers I've had as of yet not one mouse. It's parked on the edge of a field.
2016 F350 Dually
2014 Spartan 1032
2010 F250 it went to a new owner
2008 Harley Road Glide
TnT is offline   Reply With Quote
Old 06-18-2015, 06:53 AM   #15
Wolverine 1945's Avatar
We had an old Wilderness T T that we keep in the North Woods of Michigan,,, the mice would build a nest on one of our propane tanks,,, under the vinyl cover,,, so I put a hand full of moth balls on that tank one fall,,, when we returned the mice had built a new nest less than a foot away from the mothballs !!! We also used to put moth balls in the Trailer,,, till it got to smelling so bad we could not stand to use it !!!
NOT a fan of moth balls !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-18-2015, 08:54 AM   #16
Thanks for all the suggestions. Will try them out. I had similar troubles in my previous trailer. No mice for 20 years of ownership. Then felt like I was over run. The mice had started to come through the fridge roof vent after chewing through the aluminum mesh. They were also getting in through the fridge access panel on the back of the trailer. In another one I owned they managed to come through an opening around one of the vent stack caps. Once I found all the access points the issues were resolved.
I have tried dryer sheets (they used for nesting materials), tried peppermint oil on cotton balls (but again they used the cotton balls as nesting materials.
These appear to be very stubborn mice, ammune to smell, and they are deer mice, not field mice.
Will try these suggestions on locating access points.
alfina is offline   Reply With Quote
Old 06-19-2015, 06:22 AM   #17
How are they getting on the roof,,, maybe cure that problem ???
Old 06-19-2015, 06:57 AM   #18
Dave Lyon's Avatar
I had one mouse in my trailer and it entered through the propane hose inlet. I inadvertingly left the cap flipped up and it crawled in. I've not had another issue.
When storing the trailer I spread "cloves" around the inside of the trailer (on small foil plates) and outside the trailer and have never had a mouse in the trailer over the winter.
Who knows if it works.......I have not had a wolverine in the trailer either. Cloves must keep them away as well
Dave, Southern,ON
2009 GMC K1500 4x4 Crew Cab
2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-19-2015, 07:34 AM   #19
Not sure about that Dave,,, This Wolverine loves Clove,,, use it in my Teriyaki !!!
Old 06-19-2015, 07:53 AM   #20
Flybob's Avatar
Get some essential oil of peppermint ( not peppermint oil used for cooking) put 2-3 cotton balls in an old mug or glass and add a few drops of peppermint oil. Mice and spiders do not like it. It also makes the camper smell fresh and dissipates quickly once opened up. You can drive yourself crazy trying to find the holes mice get in. They don't need much of a hole. Please do not use mouse/rat poison as it causes them to be very thirsty before they die. The leave the camper to find water and can be eaten by hawks and owls who are then poisoned.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
