Old 07-23-2019, 06:19 PM   #1
Multiple Low Point Drains???
Just purchased a 2020 Coachmen Catalina Legacy 263rlsle. During the walk thru I inspected the underside and found a red blue tubes with plugs just under the side to the left of the rear door. Internally just to the left inside is the shower. The marked low point drains are on the opposite side by the waste tank drain. Asked the tech and he looked and said he didn't know. Could these be low points also??
2004 Chevy Sliverado 2500HD Duramax w/ Allison trans, 2020 Coachmen Catalina Legacy 263RLS
WD4LTO
Bookumdanno is offline   Reply With Quote
Old 07-23-2019, 06:45 PM   #2
World Wide Wanderer
wahoonc's Avatar
If it is hanging down and has a plug it is probably a low point drain of some sort. My current rig has 3, previous had 5.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-23-2019, 06:54 PM   #3
you should also have a fresh tank drain and a fresh tank overflow (I have two of those) if you have all that plus extra lines I cant answer.
Kimber45 is offline   Reply With Quote
Old 07-23-2019, 08:42 PM   #4
Yes I have the fresh tank drain too. Just strange Coachmen didn't mark these also. Thanks Aaron, I thought the same. I'll have to sanitize soon so I'll find out then.
WD4LTO
Old 07-23-2019, 09:02 PM   #5
Coach
Our fw has 7 plus the fresh tank drain. 4 of ours are marked low point. The other 3 not so much.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-29-2019, 07:55 AM   #6
Misfit Adventures
Misfit011's Avatar
low point drains enjoy your tt
Misfit011 is offline   Reply With Quote
drain
