Hello All, I love this forum. learned a lot already. Thanks
I bought a Catalina 243RBS late August (my first RV). I'm about to attempt to winterize, but a little confused. Also, I'm in upstate NY and it gets COLD.
I do not have an air compressor, so I am going to just have to do it with RV Antifreeze only.
Here's what i think i have to do so far...
1- Turn the 3 water heater bypass knobs.
2- Release the pressure on Water Heater and then Drain the water heater
2B- Remove drain plug for the fresh water tank at botton of RV.
3- Open all faucets and outside shower
4- Turn Water pump on for 15 seconds to clear water out of lines
5- Pour Antifreeze into Sink drain, Shower drain, and Toilet
6- Close all faucets and outside shower
That's what i gathered so far.... not sure if that is correct...
But i do have questions about the above...
Regarding number 4... OK so I have a Fresh Water Connection on front of RV, and a City Water Connection at rear of RV... I was told at the dealer that the water pump button was just for the freshwater connection (for when im not using the city water connection at a campground etc). So if i turn the water pump on, im assuming it will just clear the freshwater tank? and i still need to do it even if i didn't use that?
Another question - regarding 2B... Do I re-attach this freshwater tank drain plug before storing away for winter?
and yet another question: ive read that RVs have water filters.. and that they need to be removed. Does anyone know where it is in the catalina 243 rbs because i cannot find this thing.
OK, well sorry for so many questions.. I just bought it and I am hoping it doesn't get damaged the very first winter.
Thanks for reading
