Old 02-06-2017, 09:18 PM   #1
New Clipper Owner
dah1dj's Avatar
Mystery Piece of New Trailer
I'm trying the forum first before contacting Coachmen to see if any member knows what this mystery piece of siding might be. (pic attached)
This came from a 2016 Clipper 16FB and was found while winterizing, loose on the floor beside the water heater. It is a small piece of aluminum siding with a hole and a slot cut through it. My dealer has no clue why it was there.
I have 2 guesses. It was there to shield something on the water heater or it was an installation template used on the factory assembly line and forgotten about.
Any thoughts would be appreciated.
DAH
dah1dj is offline   Reply With Quote
Old 02-06-2017, 09:27 PM   #2
WolfWhistle's Avatar
Oh my! You wrote on it and voided the warranty. Good luck getting anything on that rig fixed.
Seriously, it looks like a piece of siding cut out from something that needs to penetrate to the outside. But, based on that kind of siding, which may only be part of the siding removed for it (the mysterious "it") do you have hole in the siding 10" x something high? The hole is made for the snips that cut out the piece, probably the water heater is my guess.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 02-06-2017, 09:34 PM   #3
glsimms's Avatar
I think it was something left behind by a worker on their way to lunch?
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 02-06-2017, 09:37 PM   #4
New Clipper Owner
dah1dj's Avatar
I wonder if it had something to do with positioning the propane line into the heater.
No outside holes
looks like a piece of scrap similar to the scrap they use to side the trailer LOL
DAH
Old 02-06-2017, 09:43 PM   #5
Flybob's Avatar
My guess it is a scrap piece of siding that was used as a note pad to remember some measurements. You can find lots of things, tools, zip ties etc behind panels. and drawers.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-07-2017, 09:48 AM   #6
wicked1's Avatar
Looks like part of the Flux Capacitor
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 02-07-2017, 09:51 AM   #7
I started to say that, but was afraid people would think I was weird!
WW
Hyper Lite was sold
Old 02-07-2017, 09:52 AM   #8
No outside holes
Is there an opening cut through the siding that is about 10" wide?
Hyper Lite was sold
Old 02-07-2017, 09:53 AM   #9
No outside holes
Like when they cut out the rough opening for a water heater?
Hyper Lite was sold
Old 02-07-2017, 01:35 PM   #10
bld
Looks like cut out for range hood exhaust
bld is offline   Reply With Quote
Old 02-07-2017, 01:38 PM   #11
Re: Mystery Piece Of New Trailer
TO me it might be from the hole needed for the Range Vent. Just my 2 cents worth.
cdbonnett is offline   Reply With Quote
Old 02-07-2017, 04:13 PM   #12
Rick_Geneseo's Avatar
It looks like it might have to do with the cable.
Rick_Geneseo is offline   Reply With Quote
Old 02-07-2017, 04:29 PM   #13
Yup it is the cutout for a range vent
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 02-07-2017, 05:01 PM   #14
DouglasReid's Avatar
X2
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-07-2017, 07:58 PM   #15
Garbage that they hid.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 02-08-2017, 09:46 AM   #16
Probably just trash. My 2017 Crusader was full of sawdust and hole pieces that were cut out with hole saws and old cut wire ties and dropped screws. Haven't run into anything that size but haven't been behind every wall or partition yet. They only clean what you can see when they finish the rig.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 02-08-2017, 11:27 AM   #17
mystrey peice
Looks like the cut out for the stove vent. I have a 2017 17fq and while winterizing I found all kind of trash behind the cabinets panels. And the water filter was full of plastic shavings' from hole drilling they don't clean up after building I guess to save time and money, save it for a patch in your siding for later.
cdog7201 is offline   Reply With Quote
trailer
