Old 11-09-2018, 11:24 PM   #1
New chapparral drains water out the back while filling the tank
So in my new 2019 chapparral 381 rd I was filling the frsh water tank and noticed it draining right out of the rear of the camper. Is there a close valve that I dont know of to fill the tank?
Amoroso6 is offline   Reply With Quote
Old 11-14-2018, 11:12 PM   #2
jegstrup's Avatar
That happens when the tank is full. Water xomes out of the overflow.
jegstrup is offline   Reply With Quote
Old 11-19-2018, 10:12 PM   #3
As noted above, there is an overflow...should be next to the tank drain pipe.
I had an interesting experience the first time I filled the tank just before backing into my campsite...the tank continued to drain for a longer-than-usual time. My wife said will it ever stop? I thought it was odd. Later I checked the tank and it was only 2/3 full. It had filled full when were parked several times.
I think it was draining since my rig is a couple inches high on the hitch. Never had that problem in any of my other rigs. This will be a problem since my fresh water tank is only 45gal in the first place.
We will see how it works after I install the correct track lift kit here in a few weeks. My thinking is that the over flow drain pipe must be on the rear side of the tank. Another possible cause is the siphoning action. I will investigate this one after I lift the trailer. That needed to be corrected anyway due to the attitude of the trailer while hitched.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 01-03-2019, 06:29 PM   #4
Your overflow for the freshwater tank should be right at the inlet port where you fill it. When the tank gets full the water should start coming out at that port to let you know its full. If its coming out anywhere else, you might have a problem. The only other place it "SHOULD" come out would be the tanks low point drain
Lee Pedrick is offline   Reply With Quote
Old 01-04-2019, 10:27 AM   #5
Head Rambler
That's not the case on a lot of RV's. (Though I agree that it should be.) Our vent/overflow is under the RV near the axles, which is a good distance from the fill.
Gotta go campin!
Old 08-04-2019, 09:02 AM   #6
My 2020 381RD came with the freshwater low point drain cap removed. I noticed the cap in the bay near the plumbing controls.
2020chaparral381rd is offline   Reply With Quote
Old 08-04-2019, 09:13 AM   #7
SlowrideHD's Avatar
That's the fresh water overflow and on some rigs, once it starts running out the overflow it will continue to syphon out your water until the level falls below wherever the overflow tube is plumbed in.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
drain, tank, water
