Old 12-16-2018, 12:37 PM   #1
dianeotte's Avatar
New Coachmen Catalina!
I joined this forum 2 years ago even though we owned a Gulf Stream Innsbruck. Gulf Streamís owner forum is highly geared to motor homes so I found this forum far mor informative. Sadly, our TT was stolen from a gated storage facility but I am happy to say we have put a deposit down on a 2019 283RKS! We are super excited and looking forward to being a REAL owner on this forum.
dianeotte is offline   Reply With Quote
Old 12-16-2018, 04:24 PM   #2
We bought the same model, 283 RKS Legacy Edition 2 years ago, love the floorplan. No major issues, just a few minor ones I took care of myself. Check the roof caulking, I had to add a tube of Dicor to some suspect spots when I got it home. There will likely be sawdust and metal shavings to clean up. Enjoy.
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
Crabman is offline   Reply With Quote
Old 12-17-2018, 09:24 AM   #3
(Dry Huunday)
DreiHunde's Avatar
Congrats on your new Catalina! Hopefully you will be as happy with yours as we are with ours!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 12-17-2018, 07:22 PM   #4
I have owned two Catalinas, a 253RKS & a 283RKS. Both were very good trailers for me. The only bad thing a will say about them is there is NO am antenna. No baseball games in the summer.
Besure to clear you AC filters on top, i did not and had to replace a control panel when a relay went bad, my flaute. Good camping
ilcamphost is offline   Reply With Quote
Old 12-18-2018, 01:58 PM   #5
A few thoughts
Definitely check the roof seems. I used a tube of dicor to seal them the way they should be. second, pull EVERY hot/cold register and remove (vacuum debris). I also used the real tin foil duct tape to seal the main ducts to the export ducks. I think only 1 of them was adequately installed. This made a HUGH difference in heating and air conditioning. I also "Bullet proffed" the entire TT by replacing screws, gluing wood that was loose, and using silicone adhesive where appropriate. I re-routed most of the plumbing and installed $9.00 water detectors where I could not directly access the pipes such as; near the water heater, under the shower, and near the external shower-the shelf area in the bathroom. One final; there were no washers or putty in the kitchen sink drains. Simply pull them and use plumbers putty...a 5 min job...
I actually love the layout, the large window in the living room, the kitchen but it took me 10 weeks to seal everything and so far, I have had no problems...Best of luck.
jsj248 is offline   Reply With Quote
catalina
