Old 02-18-2015, 07:59 PM   #41
No problems at all. Truck is all stock including tires.
bama29fan is offline   Reply With Quote
Old 02-23-2015, 01:55 PM   #42
blwnsmoke's Avatar
Originally Posted by mccormj45 View Post
Very nice! We are very close to pulling the trigger on a 360. One question...any issues pulling it with your F250? I have a 2009 F250 diesel (4x4). I think the 360 is the acceptable ranges for everything except the tires, but I need to confirm. Just don't want to purchase the 360 then not be able to safely pull it.
Thanks!
The truck won't have any issues towing it but it won't be legal. You will be over weight on your payload by over 1,000lbs.
Some people care about being legal, others don't.
blwnsmoke is offline   Reply With Quote
Old 04-30-2016, 11:51 PM   #43
farmncamp's Avatar
Resurrecting this old thread to reply to a comment I made a while ago.
I put the Hellwig 7271 Big Wig swaybar back on my truck in the medium setting (it was previously on high). I recently had the super fun experience of towing in a crosswind gusting to 40. You could sure feel the 5th wheel getting blown by the wind, but the swaybar did an amazing job and made the truck sit on it. I remarked several times to my wife that I didn't even have to counter steer when a gust hit.
+1 for the Hellwig 7271.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 05-01-2016, 07:24 AM   #44
blwnsmoke's Avatar
Mine just got delivered Friday and I am going to install it today.
Old 05-01-2016, 04:06 PM   #45
I am in the process of outfitting my truck in eager anticipation of my 390QSMB being built. This week I will be installing a 5th wheel hitch, tool box, and tonneau cover. I hadn't considered sway bars. Is this something you think I might need on a 2008 F-450 dually?
Also, blwnsmoke, I was reading through this thread and saw you bought from Corey Clarke at Terrytown. That's who we are buying from as well! Any advice for when we go pick it up? How long should we plan to be there?
Edit: Not intending to Hijack the thread... reading this thread raised the questions, but will start my own if needed.
2017 Coachmen Chaparral 390QSMB
2015 Ford F-350 Lariat 4X4 CC LB DRW PSD
https://www.roadschoolnotoldschool.com
https://www.roadbrewing.com
TheRowlands is offline   Reply With Quote
Old 05-01-2016, 06:27 PM   #46
blwnsmoke's Avatar
If you have a F450 you should already have a sway bar on it. I believe the F450s come with both front and rear sway bars (if I recall correctly on the front).
You could upgrade but the DRW will already handle much better then a SRW truck so I'd tow with it first and see what you think.
Advice... tell him I referred you so we each get $100 lol. Im in NH so they delivered it to me. Because of that, I didn't do a PDI. I would read through my couple of threads that I started regarding warranty. I'll edit this thread with the links once I post and search for them. I think they really rushed mine out of the factory due to my time constraints.
One thing that I would have them do is add a 2nd battery to the trailer. I think it cost me a little over $100 to have the 2nd one added. Not that we dry camp but I wanted enough juice to not have the slides be affected when moving in and out (slower speed due to less power).
If you read through my thread, make sure you check everything I listed as issues including the simple things like tugging on the corners of the carpet to make sure they were tacked down etc. Open up the couches to make sure the corners don't have tears like mine did. Open the cabinets to make sure the drawers aren't splintering. Check all the blinds and window garments to make sure there aren't any tears.
I know I wouldn't have caught everything even if I would have went there as some of the issues took 6 months for me to realize. However, I'd really spend a solid hour if not more checking every inch of it.
http://www.forestriverforums.com/for...er-100666.html
http://www.forestriverforums.com/for...ibl-69721.html
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
Old 05-03-2016, 05:31 AM   #47
shorthorn's Avatar
Great points blown... also I suggest checking drawer glides... we had several bad, and the kitchen slide out... check floor in front of couch for damage and underside fabric on slides for damage...
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 05-04-2016, 09:55 PM   #48
Honestly. airbags would probably be the better investment but I found that the OEM sway bar was great and airbags weren't needed. If you have an F450 you don't need any suspension mods. My trucks sits perfectly level with about 3k over the pin.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 05-04-2016, 10:10 PM   #49
shorthorn's Avatar
I don't think an F450 needs bags or bars to haul a 360ibl. .. my 3500 DRW does great stock.
Old 05-04-2016, 10:31 PM   #50
Ok thanks!
Old 05-05-2016, 09:07 PM   #51
farmncamp's Avatar
FYI I got under and looked my Hellwig sway bar is in the furthest OUT setting (all the way to the end). The manual said that is the least aggressive.
