Old 08-15-2015, 04:31 PM   #11
Wanna be Sir Campsalot
K4RGD's Avatar
Okay, finally got back into the camper. All fuses inside the panel near the converter are good. No breakers tripped. Checking AC on shore power momentarily.
Rockwood Freedom 1640LTD / 97 Chevy Silverado 1500
Wildwood 26TBSS / 09 GMC Sierra 1500
K4RGD is offline   Reply With Quote
Old 08-15-2015, 04:42 PM   #12
K4RGD's Avatar
Just plugged in to 110v AC. Everything inside camper functions. Hearing no hum from the converter.
Old 08-15-2015, 04:47 PM   #13
Flybob's Avatar
Sure you checked the two large fuses, they are not in the same section of the panel as the smaller ones.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-15-2015, 04:47 PM   #14
K4RGD's Avatar
Put the DC under a load (incandescent 2-bulb light) and the converter cooling fan activated.
Old 08-15-2015, 04:49 PM   #15
K4RGD's Avatar
Not sure where they would be. Attached is my fuse panel/breaker box. Any thoughts?Click image for larger version
Name:	ImageUploadedByForest River Forums1439675322.863807.jpg
Old 08-15-2015, 04:58 PM   #16
K4RGD's Avatar
Just tried pulling the plug after resetting all the breakers again. Again, everything is dead. It seems that it's all running off shore power or nothing. Maybe I have a broken wire between the battery and the converter?
Old 08-15-2015, 05:26 PM   #17
First check battery voltage bother when plugged in and unplugged. This will tell you something. Your battery could be bad.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 08-15-2015, 05:26 PM   #18
Flybob's Avatar
Large red/orange fuse on the bottom 40A.
TST Tire Monitors
2 100W solar panels
Old 08-17-2015, 07:19 AM   #19
There's an in-line fuse between the battery and the electrical panel. On ours it located at the front, drivers side corner near the inside end of the stabilizer jack. Pretty standard looking fuse holder (has a cover) but not fully weatherproof. If that fuse blew you'd get the indications you've described.
Barry, MSgt, USAF, Ret. & Rose
2017 Ford F150 w/ 3.5 EB
2014 Coachmen Viking 17FQ
Colorful Colorado
La Plata View is offline   Reply With Quote
Old 08-17-2015, 07:30 AM   #20
fonzie's Avatar
Look for a mini-breaker underneath trailer near tongue and reset by pushing black button.....hope that is it....
Fonzie
2013, coachmen, power
