Just completed a camping trip. On shore power, all was great. Came home, was starting to clean up. Electric jack works well, but there's no power inside.
Is there a breaker that takes the inside power offline?
The power connection at the campground was a bit flaky, might have been enough to trip a breaker or two.
Pretty sure the battery is fully charged. I've not tried plugging the camper in since we've gotten back. Was just going to pull from battery power for lights, etc, during cleanup. Pulling the power plug was the last thing we did when shutting down at the campground.
Check the two 30-40A fuses in the converter ( usually yellow/orange) . If the battery was low when you plugged in, or issues with campground power, I could have blown them. There are no breakers in the 12V system Only fuses. ( possibly one resettable fuse)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
It has been my habit to throw the main on the power pole before I unplug the Surge Guard to keep things to a minimum.
I then unplug the power cord from the SG and stow things away, power is also the last thing I unhook.
Post back after you have had a chance to check the fuses.
I'm pretty sure it's 12 volt I'm lacking (overhead lights, radio, etc). Not checked 120 volt.
you need to tell us if it's just 12v or 110v also.
and test the battery with a multimeter, cause the idiot panel lights are not accurate.
Yep, this is when I could tell something was a bit strange... The battery idiot light panel inside wouldn't show anything. Upon pressing the first time, it came on strong then faded away, apparently burning off whatever power was stored in its capacitors. From then on, it did nothing (making sense if it has no power getting to it). The electric tongue jack has plenty of juice to lift and lower, so I have a feeling it's between the battery and converter. I think the tongue Jack has individual leads off the battery for power (does not run through the camper's system).
About to head back to check on the fuses. Will pull a power cord and see if anything works on shore power.
Pretty sure that the Clipper doesn't have a factory disconnect switch.
Okay, finally got back into the camper. All fuses inside the panel near the converter are good. No breakers tripped. Checking AC on shore power momentarily.
Just tried pulling the plug after resetting all the breakers again. Again, everything is dead. It seems that it's all running off shore power or nothing. Maybe I have a broken wire between the battery and the converter?
There's an in-line fuse between the battery and the electrical panel. On ours it located at the front, drivers side corner near the inside end of the stabilizer jack. Pretty standard looking fuse holder (has a cover) but not fully weatherproof. If that fuse blew you'd get the indications you've described.
Barry, MSgt, USAF, Ret. & Rose
2017 Ford F150 w/ 3.5 EB
2014 Coachmen Viking 17FQ
