08-30-2016, 07:42 PM
No tire iron with Coachmen!!
So maybe this is a newbie reply but earlier this month I got a screw in my sidewall as well as in my tread pulling into the campground. Fortunately we were already in the campground so a friendly phone call to AAA happened.
I got out to put my X chocks between the tires and heard the hissing... I thought it was a propane leak until I noticed this.
I grabbed it and twisted a hair and it stopped the leak so we were good till we called AAA a few days later (no rush, we were there for 5 days).
AAA came out, I grabbed the tools and low and behold what I thought was the tire iron as not. Both AAA and I looked at it and it was too small for the lug nuts. Fortunately one of the couples that were camping next to us (family trip) had one to fit.
So I emailed my salesman from when we bought it 2 years ago because I figured Coachmen was going to give us a hard time about it. I took pics to prove it didn't fit and even noticed that on my king pin it had a picture of a 6 lug tire (I have 8 lugs) and the pattern on how to tighten. I figured that they gave me a 6 lug tire iron.
Low and behold Coachmen came back and said they don't provide a tire iron. The 2 tools that are in the storage area are to manually slide the slides in (tire iron look alike) and the other was to manually raise/lower the rear stabilizers (you can see the nut above the tire for what I thought was the tire iron).
So this leads me to say... I can't believe Coachmen doesn't provide a tire iron. I'm glad we were at the campground because if we were on the side of the road, we would have been there for god knows how long.
So to those who are not in the know like me, check your tools to make sure you have what you need in the event of a flat tire.
One thing that I loved was being able to lift the tires off the ground with the powered jacks lol. Made changing it much easier.
PS - AAA said "oh you can patch that tire and use it as a spare".. I held in the laughter thinking to myself.. with the whole china bombs already.. do you really think I'm going to patch a tire so close to the sidewall and expect it to hold up.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
08-30-2016, 07:50 PM
I have never received a tire iron with any of my units. A tire iron and jack are some of the items on most " things you need lists". In most cases the one for the TV will not work. I have always added a T handle tire iron as it has several size sockets.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-30-2016, 07:54 PM
I'll be picking one up this week before my weekend trip. Even the T style which is what we used would barely fit on the lug nut because the space between the rim and lug nut was so small. We had to tap it on each one.. will have to try to find a thin 7/8" socket.
08-30-2016, 07:58 PM
We have never received a tire iron with either of our trailers. Find the correct deep well socket and a break over bar.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
08-31-2016, 12:04 AM
Thank you for sharing so others may learn. A tire iron is worthless anyway without a jack or rapid jack too as I once learned myself on an embarrassing oversight.
Each trailer I own now (ATV/ snowmobile/RV) has a 4 way tire jack, a way to lift the trailer either a hydraulic jack or a rapid jack, a tire plug kit, and an air compressor and a "basic" tool set from Harbor Freight.
08-31-2016, 03:51 AM
I think its just due to the general mentality these days. I imagine most people don't know they could change their own tires, or would even know how, if they had the tools.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
08-31-2016, 04:08 AM
I've never had a travel trailer that came with a jack or lug wrench either.
But if you think that is bad, you better start paying attention to any vehicle you buy, as the spare tire (and associated jack/lug wrench) are disappearing there too. Do not assume a vehicle you purchase has a spare, as you need to verify it does.
I posted this awhile back:
http://www.forestriverforums.com/for...res-32197.html
AAA article from last year;
https://newsroom.aaa.com/2015/11/fla...ng-spare-tire/
AAA 2015 vehicle list without spare;
http://newsroom.aaa.com/wp-content/u...Spare-Tire.pdf
2011 Flagstaff 831 RLBSS
08-31-2016, 04:41 AM
Been camping 30 years and owned campers since 1985 none have come with tire irons.
Most people are surprised to find out spare tires are not standard either. They are an add on option. Dealers usually (not all dealers) order the unit they are selling with a spare tire though.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-31-2016, 06:16 AM
What he said!
The X shape old fashion lug wrenches are cast and have fat sockets which
often will not fit in the tight space of an alloy wheel. Some will fit some wheels but you have to check.
Harbor Freight has a couple of good long breaker bars. I already had sockets
but you can purchase them there also.
You'll also need a jack unless you can pull a good tire up on a block and
in doing so raise the flat high enough to get an inflated spare back on.
(I can)
Since I have been camping for 15 years in 4 different trailers we've never had
a flat. (probably just jinxed myself!) Saying that- I would just get the tire
properly patched and use it as a short distance spare like the man suggested.
Good Luck!
Happy Trails!!
Peace!
Dan & Rita D
08-31-2016, 06:36 AM
By the way I don't think anybody mentioned this, the "tool" you thought was your lug wrench or attempted to use as one was probably your emergency slide out wrench for when you have to manually operate your slide
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
08-31-2016, 06:56 AM
I've always used the correct sized deep socket, a short extension and a long breaker bar on my Rv lugnuts. No problems when you use the correct tools!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
08-31-2016, 07:10 AM
Both of our Coleman pop-ups came with lug wrench, and the jack methodology was the stabilizer system. Of course, last one was bought in '03
This was successfully tested (both in-driveway and under duress) on both trailers over the years.
2023 Coachman Apex UL 243FKS, 2016 F150
08-31-2016, 07:14 AM
Censored Member
No, travel trailers and fifth wheels don’t come with a jack or a lug wrench and never have as far as I know. At least they come with a spare tire, most class A diesel pushers don’t come with a spare tire.
What I don't understand about your post is, AAA came out and apparently didn't have a lug wrench either. If that is true I'd be looking for a new roadside service.
08-31-2016, 07:15 AM
And many trailers have a different size lug nut for the spare tire. I discovered this in the middle of nowhere on a trail outside of Moab. Lucky I travel with almost a complete set of tools for other emergencies that can happen.
Thought this was just on popups, until last year a fellow and his family pulled into a Moab campground with a Jayco of some tupe and had a tire going flat.
He came over and borrowed a set of deep well sockets, extension, ratchet, since he had only brought a wrench to fit the tires on the ground.
08-31-2016, 07:37 AM
Some passenger cars do not come with a spare tire.
TST Tire Monitors
2 100W solar panels
08-31-2016, 08:15 AM
Phat Phrog Stunt Crew
On one of my factory tours it was said they build them with the most bang for the buck. They will spend money on the bling items to give you the feeling of a luxury RV at mid-range price. But when it comes to basic items like lug wrench, jacks, surge protectors, a good mattress or JT Strong stabilizers, it adds to the cost that newbies wouldn't think about in their decisions. They cut their unit costs to save thousands to keep their units cheaper than other brands. So you get what you pay for in the end.
2014 Wildcat 327ck
08-31-2016, 08:26 AM
A Forest River Factory rep actually stated the second sentence in the quoted post above?
08-31-2016, 09:07 AM
Don't use a car tire iron or 4-way lug wrench on the trailer wheel lug nuts. You can easily damage the thin aluminum cap/cover on the lug nut making it difficult to remove from the lug wrench. Get a decicated thin wall socket and breaker bar and check the your lugs often. Look carefully and you can see the thin cap I'm talking about. Auto parts stores carry a good selection of replacement lug nuts.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
08-31-2016, 10:16 AM
My 2009 Pontiac doesn't have a spare [emoji51]
2015 Columbus 320RS
2008 2500HD Duramax
08-31-2016, 10:23 AM
Insert witty title here
I discovered that I had neither a jack or lug wrench until I had a blowout on the side of I95 in Georgia.
Sent from my SM-G900V using Tapatalk
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
