Old 01-29-2016, 12:00 PM   #11
Originally Posted by Alex.mcintosh40 View Post
Congrats I also picked mine up Friday are TT was a year old had the same thinking as you we got the 371mbrb by the way very nice truck parents have one I absolutely love it
Nice setup Alex! Thanks
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 01-29-2016, 06:58 PM   #12
So I removed the top bunk from the bunkhouse. Took all of 10minuted. A few pointers and steps if you plan on doing this yourself. It really makes the room feel much larger and allows easy clearance of you TV when the slides are in. Our daughter loves it. This is of course assuming you don't need the upper bunk.
1. Remove the total of two screws that hold the 2 pieces of OSB down
2. Remove the 2 2'x64" OSB boards from RV
3. Press down firmly on the fascia board below the bunk, it is simply attached with finishing tacks and will pop off with pressure (if you do not remove this panel first, you will not be able to get to the screws in the frame)
4. Remove the 4'x64" facia board from RV
5. Remove all 8 3" long wood screws (#10 square drive) from the wood frame bracing perimeter and the entire platform will drop (start with the front 2, rear 2 and then side 4 screws)
6. Remove frame from RV
Done
Old 01-29-2016, 07:37 PM   #13
I also installed LED taillights, replacing the oem incandescent dim lights. Probably the single safest investment you can make aside from better tires. A total of $50 for the lights and 30mins to install.
I'm also installing these above the fenders on the trailer. They will help me see those dark corners when turning on unlit streets. They are only about 4"x6", solar powered, with an off switch.
https://www.amazon.com/dp/B00QL2C20C..._UqbRwb3TCFVXK
And this was also put in for security
https://www.amazon.com/dp/B00MP4J9KQ..._htbRwb5FEPEJ3
Old 01-29-2016, 07:59 PM   #14
VizJedi's Avatar
Very nice LEDs.
That's one of the few things I was disappointed in with the trailer. All the interior lights are LEDs, but the exterior look like they took them off my 13 year old 5er I just sold.
For $50, I'll be doing this soon.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
VizJedi is offline   Reply With Quote
Old 01-29-2016, 08:01 PM   #15
Do the new LED tail lights also illuminate the license plate?
Bangback is offline   Reply With Quote
Old 01-29-2016, 08:29 PM   #16
Yes, there is an additional down facing LED for the plate
Old 01-29-2016, 08:37 PM   #17
Here are the lights if anyone is interested.
LED RV Camper Trailer Stop Turn Brake Tail Lights / License Light / Black Base https://www.amazon.com/dp/B00LA59QZO..._8fcRwbGT6E24E
Just remember this wiring: White-White, Black-Red, Brn-Gray
The wiring info on the back of the light is wrong.
Old 01-29-2016, 08:42 PM   #18
Jay68442's Avatar
Congrats! She's a beauty, enjoy!!
2016 Cherokee Grey Wolf 26BDH
Jay68442 is offline   Reply With Quote
Old 01-29-2016, 10:35 PM   #19
scootingranny's Avatar
Like how the room looks without the top bunk. When we removed both from our bunkroom to make it a scrapbook room, we found something kind of neat (or odd?). Under the bottom mattress the board was cut into two pieces. One covered the top of the drawers. The other had a hole drilled in it to lift it up and you could use that room for storage. Would be hard to get to if the top bunk was still on. We have one of the first 360ibls made so not sure about subsequent models.
ID:	98589   Click image for larger version
ID:	98590   Click image for larger version
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 01-29-2016, 10:50 PM   #20
Thanks! I had seen your post on that and thought about moving the brace back and adding a hinge to make it like the storage under the master bed. I could even make the drawers shorter and inclose them while putting a liftable lid over the front half with hydraulic arms.
