Old 08-06-2013, 11:45 AM   #1
Outdoor Kitchen Door support struts brackets..
Hi everyone,
Just wondering if anyone else with an outdoor kitchen has had the brackets on the door that hold the support struts shear right off or pop right out.
I have had this happen to mine. One side pulled out when in the driveway one day when closing it. The other side pulled out this past week while on vacation.
Both times the middle screw sheared right off and the other 2 pulled half way out while closing the door. I always close it at the middle to eliminate stress on one side.
When the first side broke I replaced the screws and it worked for a couple of weeks, but then the other side broke and all the screws pulled out. I had to use a 2x6 I had in the truck to support the door for the rest of the trip. What a pain!
Funny thing is later that same day I saw another seasonal with the same TT as me (FE 292BHDS) and it looks like his one side also broke as there was only 1 strut holding the door.
My TT is out of warranty now, but my dealer said bring it by this week and he'll look at it. I'll let you know what happens.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 08-07-2013, 12:20 PM   #2
daydreaming about camping
jeeplj8's Avatar
This has been a common theme for a number of brands recently. they are al using the same components and build material. One Prime Time owner stated his dealer told him one company makes the doors for all brands.
Anyway - the general fix appears to be attaching a flat piece of aluminum or heavy ABS plastic to the door material and then attaching the strut bracket to that. Most have used pop-rivets to attach that flat piece, some have used self tapping screws. I recommend adding some industrial adhesive before either rivets or screws.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 08-07-2013, 12:28 PM   #3
pwrplay,
I have the same issue currently on my 320bhds. My door is in for it's third fix!! The last time the dealer did exactly what jeeplj8 said: they mounted a piece of ABS plastic to the door and then screwed to that. Well after maybe a half of a dozen cycles it too failed! Waiting to hear back from the dealer, they have fowarded my pictures onto the factory. Will let you guy's know when something happens.
derf63 is offline   Reply With Quote
Old 08-09-2013, 10:38 AM   #4
Thanks guys,
I am taking it in to the dealer tomorrow for him to look at. I'll let you know what they say for a fix.
I think I'm going to suggest Stainless Steel bolts, washers and cap nuts and bolt right through the door with the cap nuts on the outside . That "should" hold it as SS bolts are very hard and should not shear (plus they won't rust).
Old 08-26-2013, 06:44 AM   #5
I picked up the trailer on the weekend and the dealer bolted the brackets right through the door with Stainless steel screws and nuts. Looks pretty good actually. You wouldn't suspect it to be a modification as there are just 2 small screw heads on the outside.
Lets hope it holds up.
Old 08-26-2013, 03:17 PM   #6
CRZ
CRZ's Avatar
I'd like to see a picture of that.
Anyway I had a plate welded to my factory brackets and never had I issue since.
CRZ is offline   Reply With Quote
Old 12-27-2013, 03:44 PM   #7
Scubanut's Avatar
I had the same problem with my outdoor kitchen door. I used the stainless steel bolts and washers. It has worked flawless for two seasons.
Scubanut is offline   Reply With Quote
Old 03-19-2015, 12:51 AM   #8
Scubanut's Avatar
Another problem I noticed that if it is raining and you are working in the outdoor kitchen the rain hits the raised door then water runs down to the top hinge area and I get a rain line on the back of my head and into the kitchen counter.
I tried two ways to fix it, first was to put plumbers putty all along the hinge. That worked for awhile but was just to messy. So cleaned that up then decided to move the gas strut hinges down about 4 inches to just above the counter. That worked great, the water now runs the other way away from the trailer. Added bonus you don't need to be almost 6 feet tall to reach the lid to close it.
Old 04-06-2015, 12:13 AM   #9
Scubanut's Avatar
After thinking about the water issue I had. I looked at several online pictures of trailers like mine I notice there is no obvious pattern they follow when installing these doors. Just be aware of yours and try to get so it slopes away from the trailer when it rains. Cook outside once and you will understand why.
Another issues with these outdoor kitchens is bugs( if you look behind your fridge and drawer spacers)there is a lot of direct access to the inside of your trailer because nothing is screened. If you leave your kitchen door open your will be swatting bugs that night. They have direct access to bunk house and into your furnace area and can come into your inside cabin via furnace decorative access that have direct access.
Old 04-06-2015, 12:19 AM   #10
Scubanut's Avatar
Name:   ImageUploadedByForest River Forums1428297564.510596.jpg
door
