Old 08-17-2012, 02:09 PM   #1
Hitch Pin's Avatar
Pex and shark bite ?
My tt has pex tubing in it, looks like 1/2" is this the same pex that is used in homes? I am wanting to get some tubing and some shark bite fittings so if I need to make a repair at the campground.
Hitch Pin is offline   Reply With Quote
Old 08-17-2012, 02:30 PM   #2
ironj's Avatar
cant say i have messed with my campers pipes yet, but i do recall another thread where a guy was replacing a sink and said the connectors didnt fit well?? not sure which pipe he had exactly....
i will say that pex and shark bites work very well....i use them all the time on other projects.....im sure someone else will jump in shortly and know the answer...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 08-17-2012, 02:40 PM   #3
TURBS's Avatar
It's the same
Old 08-17-2012, 03:03 PM   #4
great white's Avatar
It's not pex, but the "push in" pex fittings will work if you get the lines cut off straight and smooth and you use the sleeve insert that comes with the fitting.
Oh yeah, I'm "the guy" with the sink faucets.....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-17-2012, 03:16 PM   #5
ironj's Avatar
HA...i knew the "faucet" guy would show up!! LOL....and your right its NOT pex......technically....
my tech said "it aint really pex, but its real close n purty much the same thing from china kinda stuff"...LOL...whatever that means.....
Old 08-17-2012, 03:25 PM   #6
It means the trailer manufacturer is cutting corners instead of buying real pex lines and fittings to improve their bottom line on the profits sheet.
Knowing full well you'll be out of warranty before you have a problem with it in year two or three.
Or maybe you'll be lucky enough to never have a problem.
You just never know with questionable quality "boat products" made by someone being paid a couple bucks a day for their labor.
"Copies", "knockoffs" and "almost the same" are the standard of the day with "Made in China" products.....
Old 08-17-2012, 03:29 PM   #7
ironj's Avatar
WHAT?? cheap stuff??? NOOOOO!!!! say it aint so!! LOL
yeah..i was just being sarcastic about it....i guess
