Old 04-26-2015, 05:22 AM   #221
Cableman's Avatar
Originally Posted by UmptySquat View Post
What tired came on yours? I've been doing some thinking on how fast should I tow. My camper isn't at my house so I can't see what mine are.
Also, what's the deal if you flat? No spare. No jack. Guess it's roadside assistance always.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
Tires are constancy, china made.
Spare is up front under the propain tanks, i cauked the seams and painted it black so it doesnt rust like all those steel white wheels do.
Just carry a 3/4 or 19mm deep socket and a breaker bar. If you use a drill to put down the stabilizer jacks the same socket can be used for them.
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-26-2015, 06:09 AM   #222
KDHfan's Avatar
Max speed for camper tires is 65mph. Tires should be replaced every 3 years or 5,000-10,000 miles, no matter what they look like.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-26-2015, 06:52 AM   #223
Cableman's Avatar
Wow i didnt know they should be replaced in 3 yrs! I guess if we go with a good make then it can be treated like a car tire?
I dont really go over 65mph either.
Old 04-26-2015, 07:20 AM   #224
UmptySquat's Avatar
I'm an idiot. I knew that and totally forgot!
Thanks for the info. What jack though and lift points? Under the axle? Hydraulic?
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 04-26-2015, 07:21 AM   #225
UmptySquat's Avatar
[QUOTE=KDHfan;846488]Max speed for camper tires is 65mph./QUOTE]
Thanks. That would be my max anyway. Even in a 75 zone. I was hoping they weren't rated for 55.
I wonder if wheels can take E rated pressures to get speed higher on flat perfect highways?
2015 Apex 288BHS
Old 04-26-2015, 07:30 AM   #226
Aireggers's Avatar
Originally Posted by KDHfan View Post
Started installing the Vortex 3-speed fan today. It's a 1-person job... But a 4-hands needed job as well. Someone to hold the fan while wiring it up. Had to abandon the project until the wifey is around to help out. Will provide a few pics once it's complete. Ready to install a MaxAir Vent Cover soon too.
2014 Tundra 5.7 CrewMax
I would love to see some install pics if you get the chance! It's on my to do list as well. Thanks.
Aireggers is offline   Reply With Quote
Old 04-26-2015, 07:48 AM   #227
Aireggers's Avatar
I'm kind of surprised that the Apex came with 14's for tires. Our Starcraft had 15's which was nice, especially regarding clearance. Any idea why they chose a smaller tire?
2012 Nissan Armada LE
2015 Apex 288BHS
Old 04-26-2015, 09:55 AM   #228
Cableman's Avatar
Prolly cause the camper is lower and the axle is on the top side of the leaf spring.
Umptysquat, the jacks are on the corners under camper, Manuel scissor style.
Old 04-26-2015, 10:28 AM   #229
UmptySquat's Avatar
I thought those were only stabilizing and not literally weight bearing?
2015 Apex 288BHS
Old 04-26-2015, 10:45 AM   #230
Cableman's Avatar
2015 Apex 288BHS
Ya only stabilizing jacks. The socket is the same size and the wheel nuts.
Old 04-26-2015, 12:11 PM   #231
KDHfan's Avatar
2015 Apex 288BHS
There's some debate on these boards as to the proper way to jack your camper for a flat. Im pretty sure you don't want to jack from the frame. Some say you must lift both axles and some say there's enough weight on the other three that it won't hurt to jack just the one. If I get a flat, I'll call call roadside assistance 😁... If unavailable or I get impatient, I'll use the levelers method... Drive the good tire up on levelers and the flat hangs enough to get it changed out.
Not sure when I'll get to the fan again... Hopefully before we hit the road on Thursday.
Here's a pic of the socket Cableman is referring to. Much easier than cranking your stabilizers up and down by hand.
Name:	ImageUploadedByForest River Forums1430068152.442770.jpg
Old 04-26-2015, 12:39 PM   #232
Aireggers's Avatar
Amazon sells the socket for around $6. Well worth it. Just make sure you oil/lube up scissor rod. It will work like butter. Also, I installed a new porcelain toilet (wife very happy). The 'Thetford Style 2' fits ands looks great. I would post pics but can't figure out how, lol. Any help on doing that?
2015 Apex 288BHS
Old 04-26-2015, 01:00 PM   #233
Cableman's Avatar
I didnt mean to confuse you umptysquat, the only thing the stablilizer jacks and tires have in common are the sockets the same size!
I have the one kdh listed and a reg socket that fits my impact driver too. Both work well.
Old 04-26-2015, 01:35 PM   #234
PSUFan1's Avatar
Trailer aid tire ramp is a one way to change a tire
http://www.amazon.com/Trailer-Aid-Ta.../dp/B000I4JPZE
Tim & Tracy, Jennifer (20), Alyssa (15), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 04-26-2015, 02:11 PM   #235
UmptySquat's Avatar
Thanks guys. I'm a noob so I'm easily confused!
I bought the Andersen levelers already. I guess they'd raise enough to change it. I think it lifts 4" and the Trailer Aid lifts 4.5". Trailer Aid Plus is 5.5".
2015 Apex 288BHS
Old 04-26-2015, 04:36 PM   #236
KDHfan's Avatar
2015 Apex 288BHS
We've ALL been right there with ya. I look back now and shake my head at some of my questions... Hahaha... Just keep chugging along and try not to get too overwhelmed. Relax and enjoy.
Old 04-27-2015, 07:15 PM   #237
KDHfan's Avatar
Potential new Apex owner/Apex 288BH info
Installed the master bed overhead reading light (except for filling in the screw holes). This one will be much better than the stock light. The wife can read without me grumbling about a spot light shining in my eyes. I was initially confused... I assumed the black wire would connect to the black wire... Nope.
https://www.amazon.com/dp/B00JAJ7Q68..._DgTpvb1M95GQD
Name:	ImageUploadedByForest River Forums1430180132.685183.jpg
Name:	ImageUploadedByForest River Forums1430180145.993979.jpg
Old 04-27-2015, 07:41 PM   #238
KDHfan's Avatar
So I'm reading about a manual tongue jack crank that was supposed to come with the camper in the event of failure. Did you guys get one and what did it look like?
Old 04-27-2015, 07:46 PM   #239
burch42's Avatar
if i remember correctly it is the same tool as the one to lower your stabilizers manually.
burch42 is offline   Reply With Quote
Old 04-27-2015, 07:46 PM   #240
UmptySquat's Avatar
I know this should probably be in the tow forum but I was specifically interested in the 288BHS angle.
I'm getting new tires for the new to me truck. It currently has Michelin LT A/S tires. I want Cooper Zeon LTZ. LT=LT more or less but I was considering increasing the load rating. Tire guy says it's a waste of money and I don't need it for my camper. I'd hate the ride when not towing.
Thoughts?
2015 Apex 288BHS
