Old 04-09-2015, 12:33 PM   #121
Cableman's Avatar
Gonna add an electric out let to the back storage compartment, i have 18v makita vac, blower, drills and stuff, make it easier for charging! Guess ill add a 12v light too. And that awning mod will be sooner then later!
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-09-2015, 05:31 PM   #122
KDHfan's Avatar
Potential new Apex owner
That's beyond my skill set. Hahaha.
Dropped in the battery today (had it in my basement on a trickle charger all winter) and loaded it up. Power Jack and lights check out ok. All the other systems will have to wait another day. Supposed to rain tomorrow, but should be really nice Saturday and Sunday... So I'm headed out tomorrow to get her opened up and ready for the season. Of course my tire pressure gauge failed on the second tire I put it on... Starting already... Walmart junk... Hahaha.
FYI... Last time I checked, Old Coot only had a few sets of the awning brackets left. Might be a couple months before he gets more in.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-10-2015, 01:06 PM   #123
Cableman's Avatar
Got home backed in all safe and sound! Ill search that bracket now. Just drained the water heater and getting ready to flush the tanks, i added a cast drywell out back for it while patio was getting done a few years back. Got a few more days off, ill be ripping into some other stuff!
Old 04-11-2015, 04:06 PM   #124
Cableman's Avatar
Ran back storage electric outlet, framed and cut access door from top to shut valves when needed. Piece of cake, 12v wire going through it too will make it easy to install a light. Need help let me know!
ID:	73927   Click image for larger version
Old 04-12-2015, 01:16 PM   #125
UmptySquat's Avatar
First post for me!
I appreciate reading this thread. Lots of good ideas.
Without the entire proper loading debate, what do most of you guys use to pull the your 288BHS?
I'm curious about the range of vehicles you have all had success with. I noticed a few comments about the 5.7L Tundras but wanted other input.
Thanks!
UmptySquat is offline   Reply With Quote
Old 04-12-2015, 02:16 PM   #126
Cableman's Avatar
The camper is 5000lbs i pull with an 08 dodge ram rated for 7400lbs roughly. I dont pack heavy, no way do i load the camper with its 1867lbs max rating. Mine pulls it well but prolly at the max somewhere! Newer half tons seem to tow more weight.
Old 04-12-2015, 03:35 PM   #127
Got over to the camper one evening this week. Still can't get the stove vent cover to "unlock" outside so it will exhaust properly. Latches look like this:
Name:	ImageUploadedByForest River Forums1428870773.341343.jpg
Anyone familiar with this type? I'm about to the point of snapping them off and fabbing something different!
David & Carolyn, accompanied by
Cocoa & Shae, the Miniature Schnauzer sisters
The Bunkhouse! 2015 Coachmen Apex 288BHS
2014 Ford F-150 EB
Let's Ride
Bunkhouse is offline   Reply With Quote
Old 04-12-2015, 04:35 PM   #128
Cableman's Avatar
Just gotta push up and out, maybe push up and stick a flat head screw driver in there for some assistance!
Old 04-12-2015, 07:14 PM   #129
KDHfan's Avatar
I tow with a 5.7 Tundra... 9800lb tow. We're very light packers... I'm most likely under 6000lbs. Zero issues towing. It's the only TV I've used for the Apex so I can't say for sure about anything else. I did tow a Rockwood 2306 with a Nissan Armada (6500lb tow) and it did just ok... Tranny temps were an issue. I've heard the 9000lb tow cap. Armada's do better.
And welcome to the forum!
2014 Tundra 5.7 CrewMax
Old 04-12-2015, 07:36 PM   #130
KDHfan's Avatar
Finishing up our first trip of the year... And third trip overall in the Apex. 100% operational and ready to roll for the season.
Started the weekend off trying to burn up the hot water tank. Dewinterizing... And explaining to my 10-yo the process we were about to do and I thought I flipped the switch for the water pump... and it was the heater... I turned on a faucet and nothing... Then I heard the crackling of the empty heater. Yikes! All is well... No damage but probably took a few years off its life.
New mattress is heaven... We're back to wanting to camp because the bed is so comfortable! Hahaha.
We've decided on 3 additional mods before our next trip in three weeks (hopefully).
1. Add a pull-bar on the screen door.
2. Replace the bathroom fan.
3. Tear out the horrible shower surround and replace with one that functions.
Edit:
A 4th mod (but not sure if it's possible yet)... Replace existing bed lights with a flex light (one that you can twist and turn in different directions type) above each of the beds.
