Old 04-17-2015, 08:05 AM   #161
Aireggers's Avatar
Love ours
We were the same way when we saw our Apex 288bhs. We were hesitant on the length, towing with a Nissan Armada, but so far it has towed great. We have a blue ox swaypro 750 and couldn't be happier.
Aireggers is offline   Reply With Quote
Old 04-17-2015, 08:07 AM   #162
Aireggers's Avatar
Originally Posted by Cableman View Post
Just wondering if your guys apex frame welds look like these also? Looks a tad porous to me but im sure fine. Im gonna run a bead of black dap across upper and lower outer sides just to keep them from rusting so quick.
Ours looks like that too
Old 04-17-2015, 08:11 AM   #163
Aireggers's Avatar
Any 288bhs owners find/upgrade to a porcelain toilet that fits? We tried installing a Dometic 310 but I hit the wall and need about an inch from the back right corner.
Old 04-17-2015, 12:02 PM   #164
Cableman's Avatar
Thanks.
As far as the toilet, never thought about upgrading the it!
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-17-2015, 03:50 PM   #165
KDHfan's Avatar
Potential new Apex owner/Apex 288BH info
I assume you have the 9000# tow Armada? We purchased an Armada to tow our previous TT after Nissan told us they all had that capacity... Only to find out later that the SV trim is only 6500# tow.
The wife and I briefly talked about a full sized toilet... But our current mod list is longer than our bank account can support.
I'll be checking in on those welds this weekend.
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-17-2015, 05:28 PM   #166
UmptySquat's Avatar
Picked it up this morning. Went through everything I could get to (easily) to make sure connections were tight.
First in the mod list is a surge protector and water filter. I'm thinking these. Feedback would be GREATLY appreciated.
Progressive Industries EMSLCHW30 Surge Protector https://www.amazon.com/dp/B0050EH004..._TPxmvb1MT9GZR
Camco 40043 TastePURE Water Filter with Flexible Hose Protector https://www.amazon.com/dp/B0006IX87S..._pRxmvb1JE8FME
UmptySquat is offline   Reply With Quote
Old 04-17-2015, 06:33 PM   #167
Cableman's Avatar
I too eventually want that surge protector you listed. I should prolly use a water filter but never have, im draining the water heater and flushing it after every trip.
Old 04-17-2015, 08:24 PM   #168
KDHfan's Avatar
I have the Progressive Industries 30amp portable. I think you'll find on these boards that the PI brand is the favorite by far. A very valuable asset, in my opinion. I see the advantage of the hard wired... And to do over again, I'd consider it. But I do like being able to see it cycle through all the systems checks before I plug in... And I really like being able to keep an eye the amperage draw at any given time (the wife does make fun of me for this).
That is the filter I use. You can also find them at Walmart, if they have an RV section. I screw on my regulator, then the filter, and then the hose. Works just fine. I figure we don't drink the campground water anyway, so the filter doesn't have to be overly advanced.
2014 Toyota Tundra 5.7L CrewMax
Old 04-17-2015, 10:02 PM   #169
UmptySquat's Avatar
Do you use one of their boxes to secure it? I worry too much about theft...
I'm actually in the fence about the portable. I'm an engineer and want to see the cycling too! Plus I'm not sure where I'd mount the fixed one.
Old 04-17-2015, 10:09 PM   #170
UmptySquat's Avatar
I'm also wanting to put up one of those swing in and out shower rods. They're heavy so I'm instead considering the bowed out kind that's fixed. I'm worried about the weight pulling it out of the exterior wall.
How should I attach either to the exterior wall?
