Old 04-18-2015, 09:41 AM   #181
Cableman's Avatar
The other day when i emptied the hot water heater and stuck my fingure in through the plug, i noticed some blue chips almost like chipped ceramic! I hooked hose back up with plug out, cleaned it out nicely
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-18-2015, 09:44 AM   #182
Cableman's Avatar
The other day when i drained the water heater, i noticed some blue chips almost like ceramic chips when i stuck my fingure through the plug hole! I hooked the hose up with plug out, cleaned it out nicely
Old 04-18-2015, 09:59 AM   #183
PSUFan1's Avatar
Living through you guys right now. I think we are going to do one more season with the 23lb before upgrading to the apex or something similar. Love the double bed bunks. Kids are complaining the single bunks are too small.
Any issues with the door in the bathroom, someone opening from the outside while someone is using it? Do you lock it every time? And then remember to unlock it?
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 04-18-2015, 10:17 AM   #184
Cableman's Avatar
My wife always locks it then i yell at her for not unlocking it! Ill use it with the door open! Lol
I use the public bathroom more, let the kids and the dw use it.
Old 04-18-2015, 11:02 AM   #185
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
Originally Posted by Cableman View Post
CLT, my cable hook up leaked on the awning side with it closed, i pulled it off, cleaned the caulk off and resealed it. Havnt had a cable line plugged into any yet, i did change every single cable fitting there is! Lol
So yours was doing the opposite of mine, leaking when closed. I'll just have to take a closer look at it and see what is happening. We are switching to an annual site this year so I'll have more time to investigate and tinker around with things vs pack/unpack/put away/pack etc. HA!
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
Old 04-18-2015, 08:09 PM   #186
UmptySquat's Avatar
More questions...
I got a decent walk through but I'm a total noob about what to do when you get home or before you head home.
1. Make sure the water storage is empty? Plug on right side just behind back wheel.
2. Empty water heater? Remove anode? What socket size is that thing anyway? 1"?
3. How do I cut all power without removing a battery cable? I turned off all the breakers but radio was still on. I guess I could install an inline switch but that seems unnecessary.
Thanks as always! You guys are great!
UmptySquat is offline   Reply With Quote
Old 04-18-2015, 09:16 PM   #187
KDHfan's Avatar
Originally Posted by UmptySquat View Post
More questions...
1. Depends on how far I'm going. Less than a couple hours, I run with all tanks empty. If I'm going a good distance 2+ hours, I'll throw a couple gallons in the fresh water tank in case of an emergency pit stop. Even if you have the tank empty, there's usually enough water in the lines for 2 quick flushes. And yes... The plug to empty the fresh water tank is just behind the rear wheel on the door side.
2. I personally do not empty the hot water tank each trip... But probably should. If I notice any smell, I'll flush it out.
3. Two choices to cut all the power. 1. Add a shutoff switch... Or 2. Unhook the wires each time. I unhook the wires each time.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-18-2015, 09:30 PM   #188
KDHfan's Avatar
There is a trade off... We had the Rockwood version of the 23LB (2306)... And I was confident that I could stick it in any spot, no matter how tight. This guy does take more parking skills (but not as much as i thought). But... As you said... The kids started complaining about wrestling with the night shades throughout the night in their bunks. We also now have enough room for fido... So that saves us from sending him to the kennel all summer.
As far as the bathroom door... No issues yet. We do like it and haven't had any mishaps yet.
Old 04-18-2015, 10:40 PM   #189
UmptySquat's Avatar
Potential new Apex owner/Apex 288BH info
Originally Posted by KDHfan View Post
I have the Progressive Industries 30amp portable.
I wanted to let you know that some of the PI 30A portables are power surge indicators and do not appear to actually protect from surges once it has run through its checks.
This one does both.
Progressive Industries PT30C 30 Amp Portable Electrical Management System
Old 04-19-2015, 06:44 AM   #190
KDHfan's Avatar
This one does both.
I've been wrong before, but I'm pretty certain that PI only makes surge protectors. Just depends on how much protection you're looking for.
Here's a link to their site. They offer two 30A devices... But both are surge protectors. Amazon, Camping World and Tweety's all have it cheaper. I have the PT30C and got it from Tweety.
http://www.progressiveindustries.net...hardwired/c1ef (not sure why the link says "hardwired"... These are the portable)
