Old 09-18-2014, 07:00 AM   #11
PSUFan1's Avatar
Thanks guys. We will take to take a deeper dive when we get closer to that point of purchasing which is at least a year away.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 09-18-2014, 07:01 AM   #12
PSUFan1's Avatar
Btw kdhfan I PM you
Old 09-18-2014, 07:54 AM   #13
PSUFan1's Avatar
Can you walk around the queen bed without leaving the front room in the Apex? That was a concern of mine with the models that have the 60x74 bed. My feet already dangle of the edge of the bed.
Old 09-18-2014, 09:38 AM   #14
There is a small amount of room to walk around the foot of the rv queen bed but not much. I have memory foam mattress pad which hangs over into that area so it would be very tight to walk there.
2014 Coachmen Apex 288BHS
2013 Toyota Tundra Double Cab 5.7
Equal-i-zer 1,000/10,000 WD Hitch
Prodigy P2 Brake Controller
kj68135 is offline   Reply With Quote
Old 09-18-2014, 09:52 AM   #15
Cableman's Avatar
Any know if there is a bbq hook up under the 288bhs at all? I extended the black gas pipe to the back on my zinger, through a quick connect on that and my weber. Hope i can do the same on this one.
Cableman is offline   Reply With Quote
Old 09-18-2014, 10:21 AM   #16
Not a built in BBQ hook up, no. As I recall there's an extra port or two on the propane manifold that you could tap into.
Old 09-18-2014, 10:27 AM   #17
Cableman's Avatar
Kinda figured that, the kitchen is on the opposite side so it wont be as easy to extend the black pipe. Ill figure it out!
Old 09-18-2014, 02:28 PM   #18
PSUFan1's Avatar
That is disappointing
Old 09-18-2014, 07:12 PM   #19
Yes it is disappointing. I have a Weber Q I was hoping to pipe directly in somehow but the best I came up with was a tee right off the propane tank at the front and then a long hose out to the Q. (More or less just didn't want to take the time to figure out what fitting would be necessary and then also would need to remove the regulator from the Q so things would work correctly)
Got tired of monkeying with all that so for now just using the disposable cylinders.
(Maybe hooking it in the right way will be one of next years mods. )
Old 09-18-2014, 07:23 PM   #20
PSUFan1's Avatar
Good luck with the future mod
