Old 04-19-2015, 08:39 AM   #191
Cableman's Avatar
Your guys little led light on the electric input flip up cover work still? Mine stopped so i ripped into it, they couldnt even install the gasket correctly! One screw went through the correct hole in the gasket, the other 3 made their own hole! Gasket is cracking already from uv too
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-19-2015, 06:46 PM   #192
Cableman's Avatar
Got the bedlift kit installed. Its the small kit and ordered from pplmotorhome.
You can see in the pic what i removed and added. Gonna just shorten the heat pipe, attach it and cover electric again.
Really works well, dw is very happy!
Old 04-19-2015, 08:08 PM   #193
UmptySquat's Avatar
Wow Cableman that impressive!
UmptySquat is offline   Reply With Quote
Old 04-19-2015, 09:28 PM   #194
I want to get one of those kits, too. Looks like it will make it lots easier to access that storage. Beats holding the bed up with the top of my head while DW gets things out or puts them away!
David & Carolyn, accompanied by
Cocoa & Shae, the Miniature Schnauzer sisters
The Bunkhouse! 2015 Coachmen Apex 288BHS
2014 Ford F-150 EB
Let's Ride
Bunkhouse is offline   Reply With Quote
Old 04-19-2015, 11:00 PM   #195
Aireggers's Avatar
Very nice!
Aireggers is offline   Reply With Quote
Old 04-20-2015, 12:55 PM   #196
UmptySquat's Avatar
How are your battery boxes secured to the rail? Mine is just sliding around in it. I suppose I could bolt it to the rail but it think there are supposed to be brackets or something???
Old 04-20-2015, 01:48 PM   #197
Cableman's Avatar
I put a group 31 box on, came with 2 clips that the strap goes through then box sits on top. I screwed them down which was a pain!
If you do screw any thing down drill pilot holes for screws, then drill a bigger hole through top angle iron piece only. This will help aid in not breaking any screws as it will only be attaching to the bottom square iron.
You will see rust coming out where the top angle iron and square tube meet, run a bead of some black silicone along all that, i can see it rusting away in time!
Old 04-20-2015, 04:12 PM   #198
What do you guys use to level your Apex 288BHS at the campsite?
Anyone use the Andersen levelers?
2010 Dodge Ram Laramie Crew Cab (Hemi 5.7L)
rdnbck is offline   Reply With Quote
Old 04-20-2015, 04:57 PM   #199
Aireggers's Avatar
We use the stackable leveling blocks. Orange and look like Legos. They work well. Also, highly recommended 'x-chocks'. They keep trailer nice and stable. I would post pics but can't figure out how from an I-phone
Old 04-20-2015, 05:43 PM   #200
Cableman's Avatar
Heavy rain ='s that dam leak is back! Pulled the board off some in the front compartment, looks like its either where the awning wire enters or a screw.
Ill have a closer look tomorrow. Guess i might as well move that electric wire under the bed while i have the storage board pulled out.
