Old 04-21-2015, 08:47 AM   #211
KDHfan's Avatar
Originally Posted by Cableman View Post
Nothing can travel on the back bumper, there should be a sticker on it saying that. These frames are light weight, thin and the top/bottom is welded to the center.
I have a set of lynx levelers also, havnt used them much cause most sites around here are pretty level side to side. I used a cut up engineered bean for the tongue and stabilizers.
You guys just use one xchock? Im gonna have to try one...
X 2 on the rear bumper. It's a big no-no. It will immediately void your warranty.
As far as the Anderson Levelers... Here's a thread that gives some more information. Many guys with shorter wheel bases are modifying them so they fit.
Andersen Camper Leveler
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-21-2015, 08:46 PM   #212
Cableman's Avatar
Opened awning up and popped off channel that hides wire, its gotta be leaking from where the wire went through.
There was a pocket of water trapped inside the sealant they used. It looks like they sealed it up and stuck the channel right back on causing a dam.
I just pulled what i could off and re-sealed it, ill wait to put the channel cover back on.
If you guys see any water in the front storage this is something to look into.
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-22-2015, 07:34 PM   #213
UmptySquat's Avatar
I read that we have a water filter somewhere... I don't have access to the camper right now to look but I have no clue where it would be. True?
UmptySquat is offline   Reply With Quote
Old 04-22-2015, 07:59 PM   #214
KDHfan's Avatar
I haven't been through every inch... But I've been through most of the camper... And (thankfully) we have no water filter. I had one on my last TT... It was a pain to access to change it out/winterize. I had plans to pull it out permanently until we bought the apex.
2014 Tundra 5.7 CrewMax
Old 04-22-2015, 09:03 PM   #215
Cableman's Avatar
Nope no filter here either.
On a good note, it poured again and no leak to the front compartment! Awning wire it was!
Old 04-22-2015, 09:30 PM   #216
KDHfan's Avatar
I'll have to take a look. Was your picture taken of the inside of the awning arm while it was extended?
Old 04-22-2015, 09:49 PM   #217
Cableman's Avatar
Yup with the channel removed.
The plastic channel hiding the wire just pops out real easy. With mine the sealant blocked any water exiting the bottom once it made its way into that channel. You can just look up the bottom and see if its all sealed up like mine was.
I still have to put the channel back on but im pretty confident and happy i didnt see water there again!
Old 04-24-2015, 05:40 PM   #218
KDHfan's Avatar
Started installing the Vortex 3-speed fan today. It's a 1-person job... But a 4-hands needed job as well. Someone to hold the fan while wiring it up. Had to abandon the project until the wifey is around to help out. Will provide a few pics once it's complete. Ready to install a MaxAir Vent Cover soon too.
Old 04-24-2015, 09:20 PM   #219
Cableman's Avatar
Nice. I cant get my wife to agree on a better fan or a cover! She likes to see the sky if she looks up there lol.
The clear skylight above the tub is a plus too!
Old 04-25-2015, 11:26 PM   #220
UmptySquat's Avatar
What tired came on yours? I've been doing some thinking on how fast should I tow. My camper isn't at my house so I can't see what mine are.
Also, what's the deal if you flat? No spare. No jack. Guess it's roadside assistance always.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
