Old 04-26-2015, 05:22 AM   #221
Cableman's Avatar
Originally Posted by UmptySquat View Post
What tired came on yours? I've been doing some thinking on how fast should I tow. My camper isn't at my house so I can't see what mine are.
Also, what's the deal if you flat? No spare. No jack. Guess it's roadside assistance always.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
Tires are constancy, china made.
Spare is up front under the propain tanks, i cauked the seams and painted it black so it doesnt rust like all those steel white wheels do.
Just carry a 3/4 or 19mm deep socket and a breaker bar. If you use a drill to put down the stabilizer jacks the same socket can be used for them.
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-26-2015, 06:09 AM   #222
KDHfan's Avatar
Max speed for camper tires is 65mph. Tires should be replaced every 3 years or 5,000-10,000 miles, no matter what they look like.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-26-2015, 06:52 AM   #223
Cableman's Avatar
Wow i didnt know they should be replaced in 3 yrs! I guess if we go with a good make then it can be treated like a car tire?
I dont really go over 65mph either.
Old 04-26-2015, 07:20 AM   #224
UmptySquat's Avatar
I'm an idiot. I knew that and totally forgot!
Thanks for the info. What jack though and lift points? Under the axle? Hydraulic?
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 04-26-2015, 07:21 AM   #225
UmptySquat's Avatar
[QUOTE=KDHfan;846488]Max speed for camper tires is 65mph./QUOTE]
Thanks. That would be my max anyway. Even in a 75 zone. I was hoping they weren't rated for 55.
I wonder if wheels can take E rated pressures to get speed higher on flat perfect highways?
2015 Apex 288BHS
Old 04-26-2015, 07:30 AM   #226
Aireggers's Avatar
Originally Posted by KDHfan View Post
Started installing the Vortex 3-speed fan today. It's a 1-person job... But a 4-hands needed job as well. Someone to hold the fan while wiring it up. Had to abandon the project until the wifey is around to help out. Will provide a few pics once it's complete. Ready to install a MaxAir Vent Cover soon too.
2014 Tundra 5.7 CrewMax
I would love to see some install pics if you get the chance! It's on my to do list as well. Thanks.
Aireggers is offline   Reply With Quote
Old 04-26-2015, 07:48 AM   #227
Aireggers's Avatar
I'm kind of surprised that the Apex came with 14's for tires. Our Starcraft had 15's which was nice, especially regarding clearance. Any idea why they chose a smaller tire?
2012 Nissan Armada LE
2015 Apex 288BHS
Old 04-26-2015, 09:55 AM   #228
Cableman's Avatar
Prolly cause the camper is lower and the axle is on the top side of the leaf spring.
Umptysquat, the jacks are on the corners under camper, Manuel scissor style.
Old 04-26-2015, 10:28 AM   #229
UmptySquat's Avatar
I thought those were only stabilizing and not literally weight bearing?
2015 Apex 288BHS
Old 04-26-2015, 10:45 AM   #230
Cableman's Avatar
2015 Apex 288BHS
Ya only stabilizing jacks. The socket is the same size and the wheel nuts.
