Old 04-28-2015, 07:33 PM   #251
KDHfan's Avatar
Potential new Apex owner/Apex 288BH info
The wife was around tonight, so we decided to finally get the fan in. It actually went in pretty easily with two people. I had to clean up some sloppy work left behind by the factory, but nothing that was surprising. We left the wires longer than what we could have, but we were thinking they had them that long for a reason. You might want to trim them up a bit to keep them out of the way. I also suggest a person on the roof to align and hold the fan assembly and one in the camper to put in the screws.
The fan that is in the camper is the same manufacturer (Heng's) as the Vortex models... So the alignment was spot on for everything.
https://www.amazon.com/dp/B007AORR8W..._zFcqvb16MBFSY
Name:	ImageUploadedByForest River Forums1430267560.599143.jpg
Name:	ImageUploadedByForest River Forums1430267589.095937.jpg
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-29-2015, 05:33 AM   #252
Cableman's Avatar
Looks good!
I think they have a cheaper one also with no reverse, link incase anyone doesnt need that feature...
http://www.amazon.com/gp/aw/d/B002N1...5MCK7SVBV2QNKC
Is it quieter? Prolly moves alot more air
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 04-29-2015, 12:50 PM   #253
KDHfan's Avatar
Originally Posted by Cableman View Post
Looks good!
We don't really need the reverse feature... But wanted the 3-speeds. When we first pull into our site, I like to crack a few windows and replace all the air inside, so the "high" setting does that quickly... Otherwise, we keep it on low most of the trip.
Yes... Definitely moves more air. Not really sure about the noise. The stock fan moved so little air, we really didn't bother with it.
Old 04-29-2015, 04:08 PM   #254
Cableman's Avatar
That 3 speed is def the way to go, didnt realize the one i listed was single.
Old 04-29-2015, 06:56 PM   #255
UmptySquat's Avatar
Are you guys able to play your TV over the outside speakers? Mine doesn't seem to work on either AUX 1 or 2. Dealer said it should. Not sure if I have something disconnected.
DVD plays over all speakers just not TV...
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 04-29-2015, 07:05 PM   #256
KDHfan's Avatar
2015 Apex 288BHS
Never tried using the auxiliary inputs. However, the input source shouldn't effect your speakers... They should either work with all sources or none, in my opinion.
I will say... I opened up an access hole to get to the speaker wires a couple weeks ago..its a jumbled mess in there. I closed it up an left well enough alone for this season.
2014 Toyota Tundra 5.7L CrewMax
Old 04-29-2015, 08:14 PM   #257
Cableman's Avatar
I cant remember if the tv played through any speakers at all, i dont think it did!
You guys know i replaced mine, the main issues were
: no blueray (kids tend to pick movies in blueray these days)
: bluetooth, these days everything should work bluetooth!
As far as the wiring, the stock stereo is labeled and i believe there is a wiring diagram in the manuel too.
If you need to determine each speaker, tap a d battery neg on neg lead pos on pos lead. If you reverse it the speaker would just pull in instead of push out like its suppose to, you wont need to determine polarity though, the color stripe is the positive through out the camper!
Any questions on this please feel free to ask!
Old 04-30-2015, 06:37 AM   #258
UmptySquat's Avatar
Hooked up to 15A at home before our first trip. Fridge is on and I hear water running but no cooling. Confused...
TT is not 100% level. Is that the issue???
2015 Apex 288BHS
Old 04-30-2015, 06:40 AM   #259
PSUFan1's Avatar
2015 Apex 288BHS
My understanding is that the trailer should be level front to back for the fridge to work correctly. Side to side level is not as important.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 04-30-2015, 08:36 AM   #260
2015 Apex 288BHS
On my FE 292BHDS i had to change the TV settings to be on "Music" then i had sound from the TV through the speakers.
Loraura is offline   Reply With Quote
