Old 05-25-2015, 06:57 AM   #341
KDHfan's Avatar
Potential new Apex owner/Apex 288BH info
Originally Posted by UmptySquat View Post
Also wanted to mention to watch the current draw... Today had on AC, water heater and fridge. Proved to be too much. Had to switch water heater to gas and it was all good.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
Another nice thing about the Progressive Industries portable... It continuously displays how many amps you're pulling... So a quick look at your pedestal and you can kinda monitor.
It does seem odd, however, that just those three would trip it. We typically run all three on electric. Maybe ran a hair dryer or the microwave too?
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-25-2015, 07:47 AM   #342
UmptySquat's Avatar
I love that remote display! It was showing 32A when I started having issues. I had everything off and was ready to start flipping breakers to narrow it down. Refrigerator and water heater (had just washed lunch dishes so it was on full) were pulling 15A. AC was another 15A.
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 05-25-2015, 01:26 PM   #343
KDHfan's Avatar
2015 Apex 288BHS
Hmmm... That kinda stinks... I had a Coleman Mach 15,000btu A/C on my Rockwood and it only pulled 10A. Just had to keep an eye out with everything running. I really wish we had our Coleman back... Much quieter, and apparently, less draw.
2014 Toyota Tundra 5.7L CrewMax
Old 05-25-2015, 08:42 PM   #344
UmptySquat's Avatar
Ummm...let's say some guy was flushing his black water tank...on the final flush he closed the valve to get one last good flush....and let's say that guy started putting his hitch on his truck...then he maybe remembered after an unspecified few minutes and saw water running/dripping from underneath the back of the camper...what, if any, issue would there be?
I imagine he checked the camper and all appears normal...
Poor guy...
2015 Apex 288BHS
Old 05-25-2015, 09:39 PM   #345
KDHfan's Avatar
Poor guy...
2015 Apex 288BHS
Oh no... That poor guy. I've heard about others doing the same thing. I'd tell that guy to open up as much as he can and check for where water might have gotten to... And get some fans into that area quickly and run them for a few days. With the camper being so new, and on the final rinse, the black tank shouldn't have had too much "debris"... he should be ok. Dry it out and keep an eye out for mold and treat ASAP if any starts to develop.
Just my 2 penny's.
Old 05-26-2015, 09:02 PM   #346
UmptySquat's Avatar
Vacation this week and I worked ALL day on it!
Installed:
1. Extend-A-Shower - I have exactly what you need and how to do it.
2. Pop-a-plate
3. Pop-a-towel
4. Rewired the battery area and protected with flexible conduit - Cableman inspired!
5. Battery disconnect switch
6. Chain and master lock for battery - ordered a 12V B&D RV battery lock but it doesn't work on ours - we have an extra angle iron - we need the 6V one with a 1/2" plywood spacer.
7. Drilled propane wing nut and bracket to install long shank master lock.
Tomorrow:
1. Wash and protect roof - BEST rubber roof cleaner and protector was recommended by my dealer. Thought I'd try it.
2. Wash RV
2015 Apex 288BHS
Old 05-27-2015, 07:04 AM   #347
Cableman's Avatar
Poor guy...
2015 Apex 288BHS
I close mine too but shine a flashlight dwn the bowl to see how far along it is. How full do u think it was? Where else would it come out other then the bowl?
I bet ya its the connection at the black water flush! Lift the bottom bunk and look for signs of water on the exterior wall. Id break the outside seal and check it anyway...
Great job on your mods too! I washed mine from trip, oak pollen was so bad! My roof is still full of sap too. Im gonna need to pick up some roof sealer myself.
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 05-27-2015, 08:38 AM   #348
KDHfan's Avatar
Installed: 1. Extend-A-Shower - I have exactly what you need and how to do it.
If you have pics of how you installed, that would be great. I should be receiving mine from Amazon today or tomorrow and will install before our trip next week.
Also... I put an Oxygenics shower head in ours... Works great.
Old 05-27-2015, 06:41 PM   #349
UmptySquat's Avatar
Follow directions on the package. Interior wall was a piece of cake. Exterior was a pain with the styrofoam. Best solution I found was to drill then take dental tools to dig it out while holding a vacuum at the hole. No mess at all.
Pics are of the mounts and the screws I bought at Lowes to use with the mounts since the ones with both the shower and mounts are too long. Click image for larger version
Name:	ImageUploadedByForest River Forums1432766423.014118.jpg
ID:	78260Click image for larger version
Name:	ImageUploadedByForest River Forums1432766434.712327.jpg
ID:	78261Click image for larger version
Name:	ImageUploadedByForest River Forums1432766443.968295.jpg
ID:	78262Click image for larger version
Name:	ImageUploadedByForest River Forums1432766456.723644.jpg
2015 Apex 288BHS
Old 05-27-2015, 06:47 PM   #350
UmptySquat's Avatar
Im sure it was as full as it could get. Nothing out of the bowl at all. I checked around underneath and there was a small amount of pooling. Pushed on the cover in the low spot and got it all to drain out.
Everything seems ok for now. I hope there's just an overflow that sends it out the bottom so there'll be no 'internal' issues.
2015 Apex 288BHS
