Old 06-17-2015, 09:22 PM   #391
KDHfan's Avatar
Originally Posted by rdnbck View Post
I have a blue ox. Dodge says my ram will tow 10,000 lbs. But I would not want to get that close to the max. One big reason I really like the Apex 288bhs. I also have BF Goodrich KO2 load range D tires.
I only asked because I was wondering about the air bags. Never really thought about it... The Tundra doesn't have any issues and I wondered if maybe you had some problems towing before the Apex, or if you needed airbags after the purchase.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 06-17-2015, 10:05 PM   #392
Mostly the air bags just kept it from sagging. But realistically it only sags a very small amount once the blue ox is connected. I will get them fixed after I get home. It's not an issue for me towing without them.
rdnbck is offline   Reply With Quote
Old 06-18-2015, 04:19 AM   #393
Cableman's Avatar
I put supersprings on my 08 ram so i didnt have to worry about airing up. You prolly have a newer coil spring ram, they seem pretty soft in the rear when i was checking some out. I load my ram pretty heavy in the bed with wood, bikes and other stuff so extra help is welcomed!
I have the blue ox also the 1k ver, did it keep your setup sway free?
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 06-18-2015, 11:27 AM   #394
No big sway issues. Semi trucks make the trailer move when passing. Especially when it's windy. I use the same blue ox as you. And yes my truck has the coils which really sink down until the blue ox is connected.
Old 06-18-2015, 11:27 AM   #395
burch42's Avatar
added stabilizer jacks in front of the tires on both sides, fairly easy job seeing as I am not the handy man type, just a wanna be. LOL
Name:	ImageUploadedByForest River Forums1434644819.487102.jpg
ID:	80364Click image for larger version
Name:	ImageUploadedByForest River Forums1434644829.224842.jpg
almost no movement when in the camper with these and the X chocks
burch42 is offline   Reply With Quote
Old 06-20-2015, 07:26 PM   #396
UmptySquat's Avatar
Stove hood light sucks. Thinking of replacing with an LED. Does such an animal exist? Wondering with the 'high temp' necessity.
I still want to do that hood mod and move it out 6 inches...
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 06-20-2015, 07:36 PM   #397
Cableman's Avatar
This one http://www.amazon.com/gp/product/B00...rch_detailpage
2015 Apex 288BHS
Yes it does exist! I just put a paddle led bulb in, works great. Ill try and find the one i ordered....
This one....http://www.amazon.com/gp/product/B00...rch_detailpage
Old 06-23-2015, 08:38 PM   #398
UmptySquat's Avatar
Can you guys run AC, refrigerator and water heater at the same time off 30A? I can't. PI monitor reads 32A then the AC 20A breaker trips within a minute.
Is this a 'regular' restriction of 30A? I switch the water heater to propane and all becomes good.
2015 Apex 288BHS
Old 06-24-2015, 05:35 AM   #399
KDHfan's Avatar
2015 Apex 288BHS
I guess it depends on what else you have running. Your hot water heater will draw the most amps.
With all three on, I was showing 28amps, so I also switched my water heater to propane. I also had on a small dehumidifier, which draws 2amps... And a few interior lights.
I'm pretty sure this is somewhat common. On my previous Rockwood, all three put me at 26amps. The difference is the A/C. This 13,500btu Dometic draws about 2amps more than my previous 15,000btu Coleman Mach. Makes no sense.
2014 Tundra 5.7 CrewMax
Old 06-24-2015, 09:46 AM   #400
Blown tire
After 3300 miles (on our way back home) one of the trailer tires blew in Joplin, MO! Luckily the rubber all stayed in tact. So no damage to the trailer. I plan on replacing all these China tires when I get home!
