Old 06-24-2015, 11:04 AM   #401
Cableman's Avatar
Originally Posted by rdnbck View Post
After 3300 miles (on our way back home) one of the trailer tires blew in Joplin, MO! Luckily the rubber all stayed in tact. So no damage to the trailer. I plan on replacing all these China tires when I get home!
Wow! Goid thing all is ok. I guess these tires from china just cant handle long hauls. Its a shame we pay so much and have to replace tires.
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 06-24-2015, 06:38 PM   #402
KDHfan's Avatar
Wow... That's not good to hear. Glad all is well. I thought maybe because these tires held air so well they might actually be better than my previous Trail Express tires. Apparently not. I was hoping to get through his year on these tires... I already have over 1,000 miles on them... This has me reconsidering that thought.
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 06-25-2015, 06:23 PM   #403
Cableman's Avatar
Dropped the camper off with the dw! I roll back out east tomorrow with the kiddies
Old 06-27-2015, 05:34 PM   #404
UmptySquat's Avatar
Are our brakes self-adjusting or do I need to adjust the old fashioned way?
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 06-28-2015, 07:23 PM   #405
KDHfan's Avatar
2015 Apex 288BHS
Can't help you there. Not even sure what that means. Hahaha.
2014 Toyota Tundra 5.7L CrewMax
Old 06-28-2015, 10:17 PM   #406
UmptySquat's Avatar
Self-adjusting sort of ratchet out as the pads wear. Then when you install new pads it's reset.
Old fashioned means you have to jack up each wheel and adjust a star nut inside the brake (from an access hole) to push brakes out and compensate for wear.
I seem to have a decrease in braking with my controller turned up.
2015 Apex 288BHS
Old 06-29-2015, 07:07 PM   #407
"I seem to have a decrease in braking with my controller turned up. "
Has your trailer gotten heavier?
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 07-01-2015, 09:03 AM   #408
Aireggers's Avatar
Originally Posted by KDHfan View Post
I guess it depends on what else you have running. Your hot water heater will draw the most amps.
With all three on, I was showing 28amps, so I also switched my water heater to propane. I also had on a small dehumidifier, which draws 2amps... And a few interior lights.
I'm pretty sure this is somewhat common. On my previous Rockwood, all three put me at 26amps. The difference is the A/C. This 13,500btu Dometic draws about 2amps more than my previous 15,000btu Coleman Mach. Makes no sense.
How do you switch the water heater to propane? There's the on/off switch in the bathroom and then the switch outside on the water heater itself. Are they different? I just thought the outside switch was like a master power switch and electric was the only option.....
2012 Nissan Armada LE
2015 Apex 288BHS
Aireggers is offline   Reply With Quote
Old 07-01-2015, 10:47 AM   #409
KDHfan's Avatar
Yes... They are different. The outside switch is for electric. The inside is for propane. You can have them both on, or run them independently. Just make sure there's water in your hot water tank when you flip the outside switch or it will fry your heating element instantly. We almost always run propane only, just because of the amp draw using electric.
Old 07-02-2015, 09:12 AM   #410
Aireggers's Avatar
Thanks for the info on the water heater switches! Never knew there was a difference. You think they would have mentioned that on the walk through, lol!! In that case then, I'll just run off the inside switch and propane as well. Thanks again.
Anyone have any close call scraping the trailer's back end when towing/backing on an incline? We noticed the clearance is pretty tight back there when either backing into a hilly driveway/campsite and/or towing down a hill onto a flat road where the change is pretty abrupt. Just wondering if anyone else has had the same pucker factor I did, lol.
2015 Apex 288BHS
