Old 07-08-2015, 05:52 PM   #421
The line is just below the fork in the picture. It starts at the cabinet and runs in a straight line to almost the dinette. The floor is level under the dinette. Nothing feels soft or spongy. Hope the picture shows up well
Sweendog is offline   Reply With Quote
Old 07-08-2015, 05:54 PM   #422
The seam is just above the fork, the picture inverted. It runs for almost the length of three tile blocks. Under the dinette the floor is level
Old 07-08-2015, 06:25 PM   #423
Cableman's Avatar
Interesting, i dont have that at all. Does the flooring feel soft inbetween the gap like the floor board opened up or shrunk?
The floor is made up of 2 sheeys 1/4" luan with Styrofoam glued inbetween. When the slide is closed how do you know the gap closes up?
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 07-08-2015, 06:56 PM   #424
With the slide closed, the sink counter is tight to the wall. The floor doesn't feel soft in that area, it feels more like a support bar is there when you walk over it. It's odd that the seam is a straight line with a definite point where you can see the linoleum move. I wonder if the luan cracked at that point. I wish I had a picture of the floor construction to try and determine what's going on there. Thanks again for all your help, you quick replies keep me from losing my mind.....lol. The coach is 2014 and I wouldn't expect structural problems with it. The azdel walls were a strong point in buying this camper so I wouldn't have to worry about the wall delaminating. Hopefully this floor issue is nothing major.
Old 07-08-2015, 08:19 PM   #425
Cableman's Avatar
I was sold on the azdel walls too!
The seem is sideways but the sink cabnet pulls off the exterior slide wall? Seems odd the seem openes up one way and the cabnet moves another!
Old 07-08-2015, 08:26 PM   #426
I think that because the sofa side is lower, it causes the sofa to pull down when someone is sitting there and possibly cause a twist is the cabinet. The gap is only at the sink on the exterior wall and does not continue past the stove top. That's my wild guess. My real concern is if the floor has been compromised. I am always so worried about water damage in a travel trailer. I'll have to monitor it and see if it gets any worse over the next few trips. There are not many diagrams online about the roof and floor construction. I hope to enjoy it for many more years.
Old 07-08-2015, 08:33 PM   #427
Cableman's Avatar
Could always ask an apex rep at coachmen. Check that strip of wood under sink which holds all that to the wall also.
Is your converter under the dinette? Looks like you have a cabnet draw where my converter sits...
Old 07-17-2015, 08:45 PM   #428
UmptySquat's Avatar
Hey guys...I'm going to get metal valve stems installed for my stem mounted TPMS. I've more or less decided to take the rims in myself instead of taking the camper.
Any ideas? I wouldn't mind taking all 4 at once. That'd mean putting it on jack stands. Not sure how to do that.
Where do I jack?
Where should I put the stands?
What jack do you recommend?
Think 1 ton jacks would do the trick?
Any reason I shouldn't do all 4 at once?
Sorry...lots of questions there.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 07-18-2015, 07:23 AM   #429
Cableman's Avatar
I would say 2 jacks on one side under each spring perch lifting each tire enough to get a stand under each axel. Make sure each stand is close as possible to spring perch. Repeat for other side.
Old 07-23-2015, 02:01 PM   #430
Cableman's Avatar
Ocean this week! Dolphins in the 3rd pic too!
ID:	83887   Click image for larger version
ID:	83888   Click image for larger version
