Old 10-06-2015, 07:19 PM   #491
KDHfan's Avatar
Potential new Apex owner/Apex 288BH info
Originally Posted by UmptySquat View Post
Planning winterization at the end of the month.
Ordered an Adco Designer cover.
Hand pumping through city water connection is pretty simple.
My question is the fresh water tank, pump and accompanying lines. I don't use the tank but I know it was used to demonstrate during the PDI. I've since emptied the tank but nothing else.
Should I just put antifreeze in the fresh tank and flip the pump on? Not sure how output of pump ties into city water lines...
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
I'm certainly no expert... But I don't think you need to mess with your fresh water tank at all. I drained it last year and left it alone.
The pump is under the dinette bench next to the fridge.
Using this winterization kit ( https://www.amazon.com/dp/B0006JJ588..._luffwbE9TRY6E ) you can attach one end of this tube to your pumps inlet and the other end into a gallon of anti-freeze. From there you can just turn on your pump and winterize all the lines. This kit worked perfectly for me. It takes about 2-3 gallons of anti-freeze to do all the lines.
I would think you'd need quite a bit of anti-freeze in your fresh tank for the pump to draw it.
Edit: Here's a YouTube video that shows almost exactly how the above method goes. The only difference for me is that because I blow my lines with air first, I don't need to put anti-freeze in the city water inlet. http://youtu.be/Q5Hvn9NpJa8
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-10-2015, 11:30 AM   #492
I do not really understand electrical in this camper... But I wanted to disconnect the battery then take the camper to storage for winter. But apparently the electric tongue jack has to be connected to the battery to work. Is there any other way I can get the jack to work without the battery? My previous camper the jack would work if the camper was connected to the truck or plugged into an outlet (when the battery was not connected). Just curious if anyone has tried the jack without the battery?
Thanks!
2010 Dodge Ram Laramie Crew Cab (Hemi 5.7L)
rdnbck is offline   Reply With Quote
Old 10-10-2015, 10:14 PM   #493
UmptySquat's Avatar
The jack is direct wired to the battery. No way for it to work except for popping off the rubber gasket on top and using the spinner wrench to manually do it. Do it once and you'll know why it's electric.
UmptySquat is offline   Reply With Quote
Old 10-12-2015, 12:54 PM   #494
UmptySquat's Avatar
Anybody put valves on the low point drains? Curious what size the tubing is... Thinking of putting a quick drain valve on them and the fresh water tank.
2015 Apex 288BHS
Old 10-20-2015, 11:11 AM   #495
My tongue jack works without battery if plugged into the truck.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 10-23-2015, 11:25 AM   #496
UmptySquat's Avatar
Anybody know if the refrigerator will run on gas with the battery dead? Camper not hooked to anything else. I figured there was a powered monitoring circuit or something but I don't know...
2015 Apex 288BHS
Old 10-23-2015, 11:29 AM   #497
2015 Apex 288BHS
It won't have any juice to light the burner. You'll hear the fridge clicking and trying to light but alas it will not light.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
robertlanajean is offline   Reply With Quote
Old 10-23-2015, 12:07 PM   #498
PSUFan1's Avatar
That's what I was thinking
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 10-23-2015, 12:38 PM   #499
UmptySquat's Avatar
Thanks for the quick answers guys!
I'm thinking I have enough juice to get it lit. Battery is low but on. My worry is that I'm heading out tomorrow. I wanted to light the fridge at the storage unit this evening so it'd be cold when I picked it up in the AM. My feeling is the battery would likely drain and crap out overnight...
2015 Apex 288BHS
Old 10-23-2015, 07:12 PM   #500
KDHfan's Avatar
I always light mine the day before I head out. Sometimes the battery will drop down one level... Sometimes none.
Last trip of the season for us. Twin Grove Campground in Pine Grove, PA. Nice little campground.
2014 Tundra 5.7 CrewMax
