Old 10-15-2014, 04:01 PM   #51
Cableman's Avatar
Did they give one with the camper?
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 10-15-2014, 04:26 PM   #52
KDHfan's Avatar
No. I had one for my Rockwood, but I've misplaced it in the transfer. I wanted to check them before heading out tomorrow.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-15-2014, 06:23 PM   #53
KDHfan's Avatar
Ok... So it's a 3/4. Glad I checked them... 500 miles and every one of them needed to be re-torqued . I checked my Rockwood every few trips... Never had a single one loosen up.
2014 Toyota Tundra 5.7L CrewMax
Old 10-15-2014, 09:50 PM   #54
Cableman's Avatar
Ill have to remember to ck mine, 250 from drive home. I took that torque decal off! Just got done running that front led wire, easy untill i had to get it up to the main switch panel but its done! On the inside of the cabnet above the table are 2 removable boards left and right, these can be pushed in more prolly 8" or so for some more room.
Old 10-16-2014, 07:12 AM   #55
KDHfan's Avatar
Good to know. Thanks.
Old 10-17-2014, 06:06 AM   #56
Cableman's Avatar
We just had some heavy rain and mines got leaks! Nothing on the floor inside. I had a hole in the floor where i was snaking the wire under that front storage compartment and notice the wood floor was wet. Next to each door up underneath where the black floor liner ends against the outer walls, look for wetness. I think it may be coming from the sides of the doors where there is no caulking. The cable outlet on that side leaked too! 3 campers and they all leaked for me! Just have to find them and stop it!
Old 10-17-2014, 07:04 AM   #57
KDHfan's Avatar
Thanks. We're currently at Hershey Park and got some rain last night too. Hopefully I'll still be able to determine if it's damp.
Old 10-17-2014, 07:09 AM   #58
KDHfan's Avatar
You're referencing the compartment doors, correct? So the water was laying on the floor, inside your front storage?
Old 10-18-2014, 07:43 AM   #59
Cableman's Avatar
Left side of front compartment storage, then underneath where subfloor ends and wall bottom on each side of entrance doors. The bottom of the carpet on the night table next to the bed was also wet. I also have the frameless windows which could be a cause also, they dont caulk around them and just use that foam seal which is also around the doors.
Old 10-18-2014, 07:47 AM   #60
Cableman's Avatar
Heres my new switches with front led switch also, just put a blank plate where old switch was.
