Old 12-21-2014, 10:06 AM   #81
KDHfan's Avatar
We've talked about swapping out the unit. I think we're just going to stick with it until we have an issue. I do plan on changing the speaker wiring so that the rear speakers can be dedicated. Not sure why they wouldn't run the extra wire for dedicated C speakers.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 12-21-2014, 10:45 AM   #82
Cableman's Avatar
Rear speakers? I only have 2 inside and 2 outside. My c channel is not hooked up, just open wires behind unit. Im excited! My wife and i have been turning the heat on and kicking back a few drinks in it! Guess thats why im so motivated to mod things up lol. I got the middle ceiling light working off the switch done, i like it but kind of a pain to do. Everytime i think im done i come up with something else that would be cool!
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 12-29-2014, 09:49 PM   #83
KDHfan's Avatar
There's at least one above the bunks. It works on A or A & B, but does not work on C alone.
Old 12-29-2014, 10:01 PM   #84
KDHfan's Avatar
Cableman... Have you located the control box for the Schwintek Slide yet? I was just snooping around on YouTube recently and was learning more about the "what if" factor of slide issues. Also, I'd assume that to get to the slide motors, we'd have to remove the wood trim around the inside of the slide? Hoping I'll never need to know, but I like to be prepared if I do.
Really chomping at the bit to get back out. Made reservations today for our three annual trips to Hershey Park. Place fills up fast.
Old 12-30-2014, 07:11 PM   #85
Cableman's Avatar
I will look into the slide control box! I have had the removable front kick panels in the kitchen slide off, lotta stuff under there.
The speaker thing is easy for ya, just put 1 on c and the other on a or b, which ever one is not the outside speakers then it will have front to back control on the inside. I got mine all done, love it! Still have some indoor speakers to replace.
We are itching to get out also! Least you got to use yours already!
Old 12-31-2014, 07:06 PM   #86
On my 2014 The slide control box is under the rear bunk not far from the water heater.
Name:	ImageUploadedByForest River Forums1420074375.988389.jpg
2014 Coachmen Apex 288BHS
2013 Toyota Tundra Double Cab 5.7
Equal-i-zer 1,000/10,000 WD Hitch
Prodigy P2 Brake Controller
kj68135 is online now   Reply With Quote
Old 12-31-2014, 10:02 PM   #87
Cableman's Avatar
I guess ill have to leave the screws off that bunk just in case! Thanks for that pic
Old 01-01-2015, 07:05 PM   #88
Cableman's Avatar
Made some more usable space under the usb charging jack.
Old 01-22-2015, 06:12 PM   #89
Cableman's Avatar
Picked up a 2nd quick connect for my weber regulator so i can use a small bottle if i need to. Ordered a ss braided hose off ebay with 3/8th female flare to run to the back off the block to hook up my modded weber. Works great, just need a shutoff and then ill mount it just left of back steps.
ID:	68750   Click image for larger version
ID:	68751   Click image for larger version
Old 01-23-2015, 07:48 AM   #90
Last pic is very helpful, now we know what we're looking for!
Do you know where the water pump is hiding? We did finally modify the bunk to get to the bypass valve on the hot water heater, but the pump isn't in that space .. that I could see.
Also, we supposedly have heated tanks. How's that work?
David & Carolyn, accompanied by
Cocoa & Shae, the Miniature Schnauzer sisters
The Bunkhouse! 2015 Coachmen Apex 288BHS
2014 Ford F-150 EB
Let's Ride
Bunkhouse is offline   Reply With Quote
