Originally Posted by Sarjent
Hoping someone can help me trace this out. I replaced my battery this spring. I can attach a multi-meter to my battery and get around 12.6v DC. However, nothing inside is powering on. I have reset the circuit breakers.
What else can I look at or where to continue troubleshooting?
THanks
2016 Clipper 17BH
If you happen to reverse the battery cables (hook them up backwards - battery cables don't always follow an expected color code), you will blow out the two reverse polarity fuses in your fuse area. They are usually 30-40 amp fuses. The are usually NOT in line with other fuses for water pump, lights, etc., but are together near a sticker that says something like "Reverse Polarity" fuses.
Secondly, check your battery disconnect switch.
If that's not the problem, we'll dig deeper.
