Old 03-29-2019, 07:08 PM   #1
swampdonkey772's Avatar
Propane quick connect
Hey all looking for some input. I'm going to install a quick connect onto my trailer. My question is where to mount it. Should I mount in the outdoor kitchen itself or near the rear bumper off the frame? All cocking is done at the rear of the trailer near the kitchen. For you that have them where does the factory mount them on trailers.
swampdonkey772 is offline   Reply With Quote
Old 03-29-2019, 10:13 PM   #2
I prefer the connection to be low to the ground to reduce necessary length and so most of the hose is not a tripping hazard so under the outdoor kitchen seems better than in kitchen itself.
Hope that helps.
Skip12 is offline   Reply With Quote
Old 03-29-2019, 10:17 PM   #3
Hope that helps.
Thanks for the input. I was planning on running it under the trailer from the distribution block to wherever I plan on putting it. I have an 8ft hose coming. If it's low to the ground is it a pain to hook up?
Old 03-29-2019, 11:07 PM   #4
Yes, if its low to the ground and recessed, its awkward to connect and disconnect but only for a second.
Old 03-31-2019, 09:21 PM   #5
How do they attach them to the frame
Old 04-11-2019, 01:22 PM   #6
JGriff's Avatar
YouTube it. That's how I found out how to do it
JGriff is offline   Reply With Quote
Old 04-11-2019, 01:42 PM   #7
Here are a couple examples...
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 04-11-2019, 05:58 PM   #8
Thank you. I've searched all over. Where did you find these. I'm still trying to figure out how I'm going to connect the quick connect to the distribution block as none of the current connections have a swivel adapter and i need to pull one out to connect the T from the box to attach my quick connect
Old 04-11-2019, 10:29 PM   #9
The photos were all Google images.
Google is your friend!
Old 04-11-2019, 10:35 PM   #10
I guess i need to brush up on my Google skills. So I think I've found a way to make this work. I'm going to just T off from the regulator and run a dedicated line to the quick connect hose. It's the only way I see
propane
