Old 10-13-2015, 12:09 PM   #11
Always
We always remove everything from the trailer before putting it away.
Why take chances? I would hate to find shredded everything all over the inside of the cupboards.
RussPastuch is offline   Reply With Quote
Old 10-13-2015, 12:32 PM   #12
PhoneDude 8289's Avatar
We remove any and all food after every trip if the RV will be stored for more than a week. All clean linens and clothing are kept in there place in the RV. Any unclean items are taken to our brick and sticks home, cleaned and replaced in the RV ready for the next trip.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 10-13-2015, 04:00 PM   #13
MilCop4523's Avatar
Originally Posted by Brother Les View Post
Put a few mice baits around the inside of the unit. In over 30 years of camping we have always left the 'camper linens' in the camper all of the time.
Why would anyone offer a supply of food to bring mice in for a snack?
Go get some FRESH CAB which keeps them out of your trailer!
We use it and leave linen, toilet paper, towels and last year food tissues and other nice things and. No sign of a rodent
MilCop4523 is offline   Reply With Quote
Old 10-13-2015, 05:18 PM   #14
Mice Oh no!
Originally Posted by Vallgrlx2 View Post
Greetings All:
Getting ready to place the Coachmen Catalina 243 RBS into hibernation for the winter (sob!) Besides winterization of the plumbing systems, what do you recommend removing from the TT and storing at home?
We are concerned about mice etc. a friend suggested removing all linens, blankets, towels and storing at home. Ideas? Suggestion? We live in Nebraska and temps can get -20 in the winter.
2016 Coachmen Catalina Banner Edition
2014 Ford F-150 with Ecoboost, 4WD
Two sassy Scottish Terriers😌
Most folks worry about the issue of mice in their coach over the winter, the first thing you should have already done is to seal any and all openings in the bottom of the coach with expanda foam, this will slow down the mice, then go inside and do the same in all the areas you can reach, (under all the sinks, beds etc.) then if you have a area under you bed for storage you can put the items in plastic bins or take home. As for food items yes every single item comes out you do not want to feed the little bastards.
Now for other things to do, vacuum the coach, take out any thing that can make bedding (toilet paper, tissues) and box then up, then put "Fresh Cab" all around your coach and hope for the best in spring.
Good luck i will cry with you (will be winterizing mine this weekend) and then just dream for Happy Camping for next year.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 10-13-2015, 06:18 PM   #15
MilCop4523's Avatar
Have to winterize ours tomorrow. Predicting snow flurries Saturday and Sunday here
Last Saturday night it was 30 degrees F.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
Old 10-13-2015, 06:27 PM   #16
Cyber Phrenologist
Radio's Avatar
Don't forget to plug your vents with vent cushions.
Trying a new thing this year: Buying cheap dark colored towels at Walmart. Clipping them to the window valances with clothes pins or "bulldog clips" to block out the UV light and provide some insulation. Also makes it harder for would be thieves to case the trailer.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-13-2015, 06:40 PM   #17
mark0224's Avatar
We store ours at home and keep our towels an linens in the trailer all winter, my wife made some little cloth bags full of spearmint leaves and we set mouse traps. The only time we had a mouse problem was when I parked it too close to the uncut field next door and forgot to put the traps and spearmint in the trailer.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-13-2015, 06:58 PM   #18
It is hard to keep em out.
We have had mice problems with two of our campers over the years and finally decided to remove all linens, paper, etc. when we winterize. It is often a nearly impossible task to keep those little critters out and it is hard to believe how small of an opening they can get through. One of our campers had a problem with the seal around a slide that I simply could not find a way to seal based on its location and access. One thing for sure, if you have a mouse invasion, you will have a different attitude about the whole matter.
magpi26 is offline   Reply With Quote
Old 10-13-2015, 08:35 PM   #19
Originally Posted by Cookies & Chips View Post
several Bounce dryer sheets around the floor ... not sure if it really works, or is just a wives tail ... but we've never had mice in our trailers or those they we've recommended this above to as well.
Good Luck!
I too use dryer sheets! I put the linens in a plastic bin. Remove all food products. I still use the dryer sheets all over sheets that I leave on the bed to keep mice from burrowing into the mattresses. I use the dryer sheets on my booth seats...again, I cover the seats with sheets though so the oils from the dryer sheets won't stain them. And I tuck the dryer sheets down the cracks of my couches etc.
lindalees818 is offline   Reply With Quote
Old 10-13-2015, 09:28 PM   #20
WFD
Another vote for removing all linens and paper items as well as all food items. A good cleaning prior to storage and plenty of Bounce sheets everywhere, including outside storage compartments. No problems in 4 years, so we keep rolling with it.
We have also been told that mice do not like limestone so the storage facility we use is a limestone lot and no trailers are stored on grassy areas.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
storage, winter
