Old 04-17-2016, 02:03 PM   #11
wingedone's Avatar
Originally Posted by TheRowlands View Post
We placed the order on April 8. Does anyone know how long it takes them to actually start building it?
Can't tell you when it will go to production, but once it hits the production line, it's about a day to two, to build. Last time we were there, they made Chappy's and Brookstones on the same line (but all Chappy's, then a run of Brookstones, then back and forth).
They have to make a certain number per day. So they almost never put in more that 6 hours a day. Great incentives for quick production. Lousy incentive to produce quality work.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 04-17-2016, 02:04 PM   #12
blwnsmoke's Avatar
When we ordered our Chaparral 390QSMB a while back, we chose to decline the 40" television option. It was around $719, and we figured we can just use one we already have, or even buy a new one for less than half that.
However, someone elsewhere mentioned that when you order the TV from the factory, that also includes the wiring, antenna, and booster. By declining the TV, you also don't get those things. Can anyone give some insight on this? Do I need to have the TV added before it's too late?
I ordered my 360IBL without the bedroom and kitchen TVs because of the same thing. I could get better quality for less or larger size for same price.
The only thing that is missing is the TV mounts on the camper.. the wiring is all there.
I did talk with the factory and request them to include the mounts which they did at no cost. My fear was to drill into the walls in the wrong spot and missing support beams and/or leaving holes because I had to drill again.
I'd highly recommend contacting the factory and request the mounts be installed even if you have to pay for them.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 04-17-2016, 02:17 PM   #13
Another consideration, the RV TVs are 12 volt and are more expensive. If you are always going to be on shore power a household TV would work.
When we purchased our Class C, it came with a 12 volt 32" LCD TV. Checking on line, they were pretty expensive comparing a 120v TV, but a bit cheaper than the factory installed. However we got the mount, wiring etc. To us, it was worth having it done as a package--and, I am an avid DIYer. We installed a 19" 12 volt TV in the BR. We managed to find a bargain on the Net, but still not cheap.
PenJoe is offline   Reply With Quote
Old 04-17-2016, 02:26 PM   #14
Not all RV TV's are 12V. Both of mine are 120V.
Aren't RV TV's built stronger to withstand the constant bouncing?
2015 GMC Denali 3500 4X4 Duramax
2015 Cedar Creek 36CKTS (flooded 2-20-18)
2019 Cedar Creek 36CK2 (picked up 5-1-18)
grumpyoldman is offline   Reply With Quote
Old 04-17-2016, 03:26 PM   #15
Herk7769's Avatar
No, they are just very cheap flat screen TVs.
I wish they had a "Flat Screen Ready" option so you can buy your own TV.
I prefer LG Smart TVs so I can stream MP4 videos to them.
The LG 3D TVs use "Real3D" glasses from the movie theater and so are "recycled" to the house.
HAM CALLSIGN - KC3FFW
Old 04-18-2016, 12:24 AM   #16
Tom48's Avatar
Ours ordered a month and a half ago and factory says production of our model started last Friday. I will tour the factory Tuesday and will learn more but was told actual production of unit takes two to three days
Tom48 is offline   Reply With Quote
Old 04-18-2016, 09:06 AM   #17
I just spoke with someone at Coachmen about not ordering the TV, causing the other things to not be installed. He laughed and said that's not true. Everything will be there except the TV. Yaay!
2017 Coachmen Chaparral 390QSMB
2015 Ford F-350 Lariat 4X4 CC LB DRW PSD
https://www.roadschoolnotoldschool.com
https://www.roadbrewing.com
TheRowlands is offline   Reply With Quote
Old 04-18-2016, 01:15 PM   #18
wingedone's Avatar
Good deal. Figured in this day it would, but best to know for sure.
Our 88 Jayco didn't come with an antenna or related items. Everything had to be ordered separately back then. Like in the 60's with cars.
Swivelwheel 58DW
Old 04-18-2016, 04:58 PM   #19
I was also told that they schedule builds for this model every Wednesday. Ours would have been on the schedule last week, but there was an email server problem at the dealership, so the order was sent too late. The good news is he said ours will be on this week's list, and it should be ready in about 4 weeks. So excited!
Old 04-18-2016, 05:16 PM   #20
leefl's Avatar
Be warned that if they do supply the TV mount it may not be suitable for your specific TV.
I recently looked into replacing the main TV in our 5er, but the supplied Toshiba TV had the mounting holes much lower on the TV than a same-sized Samsung, so to install the Samsung I'd have had to move the mount.
I may still do that at some point, since the contrast on the Toshiba is terrible, but the Samsung I'd ordered got sent back because the "Super Fast Quad-Core processor" was way slower than on the cheaper Samsung I have in the bedroom (It took about 2 minutes just to bring up the on-screen display. Extremely infuriating)
BTW, our factory-supplied TV was 120v AC, not an RV-specific 12v model.
(I'm sure we paid way over the odds for a pretty terrible TV)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
television
