Old 05-09-2015, 06:02 AM   #1
Removing TV from spinning console on freedom express 292BHDS
How does the TV come off the mount for the spinning console,between the living room and bedroom?
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 05-09-2015, 06:46 AM   #2
KyDan's Avatar
I do not have your exact trailer model but MY tv just lifts off a V shaped mount in the
back. No catch- just grab the TV by both lower corners and lift up and out.
You'll need a friend to disconnect wires unless you can do it ahead of time.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 05-09-2015, 01:26 PM   #3
Thanks! I will give that a try.
2013 RAM 2500 CTD
Old 05-09-2015, 02:26 PM   #4
you must remove the back panel from the spin frame. You will see 2 vertical boards with the TV mount bolted to it.
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 05-20-2015, 09:35 AM   #5
Yup this was correct. After struggling to try to lift it off I wrote FR. Their reply:
Good afternoon,
There is a panel on the back side of the TV box which must be removed. The back off the TV bracket can be seen, the screws attaching the bracket and TV can be removed.
Steve Brandenberger
I find this to be a poor design and once I get the panel and TV off I'll look for a suitable replacement mount that allows the TV to be more easily removed (and thus used in the bunk room or outside).
2013 RAM 2500 CTD
292bhds, freedom express
