Originally Posted by stevegotl
Excellent, Thanks Fella10. So, how did you mount the antenna on the top of the pole? Did you use some sort of adapter?
I drilled out the rivet and removed the threaded tip used to attach a paint roller, ... then clamped on a piece of thin wall 3/4" pvc pipe to have a better fit that my antenna would clamp onto, ... another thing about the 24ft pole is the length, it is in three sections 8ft each, with a compressed length a few inches over 8ft , ... you may have more room than we did, but that's a serious length for storing in or around a small trailer, ... I could have cut off a few inches and fit it into one of my 5" vinyl posts, but didn't want to cut it, ... found the perfect place to store it above our 9 1/2ft slideout, made two clips to hold it in place and that works great for us, ...
I've not needed to run my pole up the entire 24ft, I run both inner sections out about half way(then its about 16ft), and sitting on top of the bumper, 18ft has always been high enough for our use, ...
