Old 05-12-2019, 08:56 AM   #1
Replacement antenna on Freedom Express 246RKS
Does anyone know if there is a replacement antenna that can be used on the Freedom Express 246RKS?
stevegotl is offline   Reply With Quote
Old 05-12-2019, 02:50 PM   #2
bikendan's Avatar
Radio or tv antenna?
Equalizer WDH
Old 05-12-2019, 03:01 PM   #3
TV antanna... we are on the fringe and the reception goes in and out.
Old 05-12-2019, 03:11 PM   #4
bikendan's Avatar
What kind of antenna is it? Batwing or disc?
Pics help.
Equalizer WDH
Old 05-12-2019, 03:24 PM   #5
I'm not sure it's either. Here's a picture of it
Old 05-12-2019, 03:29 PM   #6
bikendan's Avatar
Not familiar with that type but I'm sure someone is. Does it rotate or is it fixed.
My rotating Winegard Bat wing with the Wingman add-on, does a great job.
I hear good things about the King Jack antenna.
Equalizer WDH
Old 05-12-2019, 03:30 PM   #7
It does not rotate and is simply fixed. Any help identifying a easy on replacement would be appreciated. I really don't want to change the mount or have to drill through the roof.
Old 05-12-2019, 03:52 PM   #8
bikendan's Avatar
Unless someone had the same unknown brand/model of yours and replaced it, don't know if anyone could recommend an easy on replacement.
Equalizer WDH
Old 05-12-2019, 03:57 PM   #9
.... Any help identifying a easy on replacement would be appreciated. I really don't want to change the mount or have to drill through the roof.
Our factory antenna has never been reliable, after about two years of fooling with it, I just abandoned it and replaced it with what the pics show, ... mounted it on a 24' painters pole from Lowe's and run the cable into the trailer thru the propane hatch on the front side, ... and use antenna point app to know what direction to point the antenna, ... the difference is amazing, from such an inexpensive setup, ...
https://www.walmart.com/ip/Onn-4K-Hd...Range/56136521
ID:	204393   Click image for larger version
ID:	204394   Click image for larger version
ID:	204395   Click image for larger version
ID:	204396   Click image for larger version
fella10 is offline   Reply With Quote
Old 05-12-2019, 04:02 PM   #10
Flybob's Avatar
We have the same one and it is virtually useless. I considered replacing it with a Jack ( has a good reputation), but the jack needs a fairly large hole for the rotating mechanism. The one you have has a small hole for only the coax. There is no replacement head that works well. I now use same system as post above. 3rd party amplified antenna on a painters pole.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
antenna, freedom, freedom express, replacement
