Old 05-15-2019, 07:41 PM   #1
Replacing globes on pendent lights over island
Hello all,
I have a 392mbl and the globes are cracked. I order new ones from coachman but I can't figure out how to replace them. They are LED lights and there is a retaining nut in the middle of them but the LED pad is soldered through the center. Not sure how to explain it really but I was wondering if anyone has had to replace these and might have some advice.
Thank you
Jeff
2014 RAM 3500 CTD
2018 Coachman Chaparral 392mbl
2001 Sunline T-267SR (for sold)
____________________________________________
"The true measure of a man is how he treats someone who can do absolutely nothing for him" - unknown
Gixxer340 is offline   Reply With Quote
Old 05-16-2019, 11:59 AM   #2
Head Rambler
A couple of pictures might help. Someone may have the same fixtures in a different RV. Or someone might know how to take them apart once they've seen them.
Gotta go campin!
Old 05-18-2019, 05:11 AM   #3
Here are pictures.
ID:	204851   Click image for larger version
2014 RAM 3500 CTD
Old 05-18-2019, 06:22 AM   #4
nomad297's Avatar
Have you received the new globes yet? If not, maybe when you see what they send to you, it will be obvious.
Bruce
Old 05-18-2019, 03:26 PM   #5
Head Rambler
You may need to take it apart starting at the ceiling mount and work down to the globe.
Gotta go campin!
Old 05-19-2019, 09:04 AM   #6
WNY_Clipper's Avatar
It's hard to tell from your picture, but mine had a threaded collar that held the globe in place. I had a access it from inside the globe
2017 Coachmen 17FQ Clipper
2017 Toyota Tacoma 4x4 TRD Sport
WNY_Clipper is offline   Reply With Quote
Old 05-20-2019, 07:03 PM   #7
jtatum65's Avatar
As stated by SWMelton, the complete assembly has to be replaced, ask me how I know. LOL! The replacements you will get will not be the same fixtures, they have since changed to a lighter glass globe and the base mount does not match the mounting holes already in your ceiling.
What I did was swapped the base mounts by removing the nut that holds it to the stem. That way the mounting holes are the same and you are not having to create new ones.
Note: That Coachmen and Shasta FW are manufactured in the same plant.
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2019 = 26
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 05-23-2019, 06:34 AM   #8
Than k you all for the input. I think I must have to replace the entire unit as there seems to be no way to separate the globes from the stems. Even though the ones that Coachman sent me were separate globes. I will have to get ahold of someone in support at Coachman and see how I can get the entire units.
Thanks again for the input
Jeff
2014 RAM 3500 CTD
Old 05-23-2019, 07:50 AM   #9
jtatum65's Avatar
Jeff
Jeff,
Send me a PM and we will arrange a skype call or something and I will help you with this, as I have already done this on my FW.
Jim & Evelyn Tatum
Old 05-23-2019, 09:44 AM   #10
Originally Posted by jtatum65 View Post
Jeff,
Thank you for this generous offer. As soon as I have the new pendents I will send you a PM.
Thank you again
Jeff
2014 RAM 3500 CTD
light
