Yes, it is ok to cut the wires apart. The clear wire nut is crimped on so you will have to cut it off to replace the sconce.
The reason for the 2 white and 2 black/white wires in your wall is that there is a pair (1 white, 1 black/white) for the power supply to the sconce, then the other pair goes to another light fixture. It is a common wiring practice when a single switch is used to turn the lights on. It is also common if each light has it's own switch in the base plate. This is the same practice used when a single switch operates 2 or more lights in a regular house.
Richard & Jill
