Old 05-21-2018, 12:24 PM   #1
Safety Strut use
Bought these safety struts 18 months ago and never installed them. Anyone using them on a Clipper? Curious if they will allow me to use a bike rack on the rear safely.
I really don't want to put four bikes in the camper any more. I've been lucky not to scratch anything. I also don't want to create a road hazard either.
Sarjent is offline   Reply With Quote
Old 05-21-2018, 12:36 PM   #2
rsdata's Avatar
I suggest that you read over this current thread...
much info on the Mount N Lock struts
Bumper Receiver
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 05-22-2018, 12:20 PM   #3
I went and read the thread. Thanks for the link. I am still as confused as ever. There are so many varying opinions on that thread and other similar topics. I guess there really is no definitive answer and safety being foremost would dictate that I should find an alternative location.
Old 05-22-2018, 03:51 PM   #4
Sarjent,
There are SO many anecdotal stories regarding rear bumpers and safety struts that it's difficult to know what to do. I'll try to cut down to the basics.
1) Your rear bumper is very flimsy and manufacturers recommend NOT attaching anything to it except for the spare tire.
2) Those safety struts do NOT add rigidity or strength to your bumper. They DO add an element of safety for WHEN your bumper fails. These only prevent your bumper from completely falling off. They don't prevent your bumper from cracking and breaking off at the welds.
3) There is another option to add a bike rack to the rear of your rig in the form of a receiver hitch that is bolted directly to the frame. You can find it HERE. This is the only real way to carry things safely on the back of your clipper.
4) Many people will jump all over this and say that "you'll be fine, I've been doing it for years!" But it's only anecdotes.
5) That receiver hitch that I linked above didn't fit on my TT, so I fabricated my own to bolt directly to the frame and it's bombproof.
kfergiez is offline   Reply With Quote
Old 05-22-2018, 06:01 PM   #5
Thanks,
I was looking at a Reese flavor.Reese Adjustable Hitch
Old 05-22-2018, 06:15 PM   #6
Yep. That will work too.
I like the Curt because the load is on the vertical piece of steel and not the horizontal.
Old 05-22-2018, 09:41 PM   #7
I used the safety struts on my keystone bullet bumper and pulled 900 miles each way with a bolt on curt receiver hitch, 100 lb generator, 30 lb cargo rack, and 6 gallons of gas. No flexing and no problems. A bike rack with a couple of bikes will weigh much less than that. I did relocate my spare tire to a rack under the camper so it removed that weight from the equation.
spdracr39 is offline   Reply With Quote
Old 05-22-2018, 10:36 PM   #8
This is what I mean by anecdotal.
Your keystone may have a heavier bumper, but the vast majority of RV bumper is made out of 14g steel. It just isnít made for a lot of loads. Most RVs also have a sticker stating that fact.
Old 05-26-2018, 08:45 AM   #9
My real life experience is they worked fine and as advertised in my situation. There is nothing "anecdotal" here YMMV.
Old 05-29-2018, 03:46 PM   #10
Bumper came un-welded/off while driving down the highway. Anyone ever heard of this ha
See this thread.
safety
